killed my case 580c
   / killed my case 580c #21
if its turning at the crank shaft pulley its turning at the flywheel i have never seen one brake a crankshaft and the front pulley turns and the flywheel dont it will have to be a really clean brake i would put the starter back on and jump the soleniod a cross the two large prongs and see if it will start u dont even need the key on i believe that machine has a manual kill if i am thinking right i know a 580 b does
got it running! i was playing around with it, and replaced the positive terminal clamp. the old one fit kind of loose.
touched the starter, and it fired right up. i don't know why it failed when it did or why the engine stopped because of a faulty battery terminal, but i am so glad it did, because it saved me a rebuild.
I limped out of the woods where i was working, got it on a level area and shut it down. i have to degrease the entire front end and check all the fluids, and hopefully I can finish my project.
Thanks a bunch for your help.
-matt
   / killed my case 580c #23
I'm a little late to answer but if I had been earlier I would have told you the engine is fine.
I had a Chevy van that my employees never checked the oil on AND IT LEAKED. They pulled up one day and it was knocking like a machine gun.
The mechanic said it was gone. I filled it up with oil, it knocked, then stopped and I ran that vehicle for another 100K miles.
I can go on and on about running vehicles with NO oil but it's not as bad as people tend to make it out.
Here this explains it better than I ever could. This engine had SAND in it and NO OIL.
Water and Silica sand
YouTube - Volvo Cash for Clunkers Engine Disabling
YouTube - Cash for Clunkers: How to destroy an engine.
   / killed my case 580c #24
You might want to change the oil filter a couple of times in case it scraped up any metal filings inside. I think you said it did run dry on oil at first right?
KUBOTA BX2350 TRACTOR (A54756)
KUBOTA BX2350...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2015 Hyundai Sonata Hybrid Sedan (A53424)
2015 Hyundai...
NEW HOLLAND TN95EA TRACTOR (A54756)
NEW HOLLAND TN95EA...
2014 CATERPILLAR 336EL EXCAVATOR (A52705)
2014 CATERPILLAR...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
