King Kutter disc is a piece of garbage
   / King Kutter disc is a piece of garbage #41
I always have to remind myself that these implements are blacksmith type items, not space shuttle parts. Even though I'm the first generation in five on both sides of my family that weren't raised on the farm.
I have to expect a little massaging for a couple reasons. I've left the family white collar business and am trying to start a small business doing rural land tending on a limited budget. Secondly, most of my work has to be done by trailering my JD790 and implement(s) on a trailer to jobsites. I'm thankful that using tractors and implements takes a certain mindset and handyman type skills. That leaves a lot of potential customers who aren't equipped to endure what we do.
I think you're on the right track with adjusting things on that disk to make it more usable including the locking nuts on the adjusting arms instead of locknuts. Sometimes the lower priced equipment comes with small parts that really aren't right for the application but a simple substitution cures a problem.
I can't use the higher priced items like disks because they are built too good. That's right, try to load a Landpride 6.5' disk with 20" disks onto a trailer with ramps behind a 28HP tractor. The implement is too big/tall to transition the angles to load and unload. I just have to buy the cheaper stuff and use some restraint when operating them. KK stuff is pretty good but you may need to blacksmith a little from time to time.
   / King Kutter disc is a piece of garbage #42
Kinda resurected a somewhat older thread here. Hope your heart proceedure went well. :thumbsup:
Just wanted to say that I have a similar KK box frame disc....and I echo the OP's frustration with the disc when new. The set up on mine was horrible and it took me quite a while to get everything adjusted right too. I had to replace some of the bolts IIRC and swinging those big wrenches is no fun. Even now, this disc is not very easy to adjust....but mine has worked pretty well as I have it set up now.
Also, I think I paid $850 for my KK 5.5' Box Frame disc. I think the price you stated was pretty stout for this disc.
Seems like it would not take much more to build it right....but it is true with so many things today. I hate having to re-engineer this stuff to make it correct....sadly that is the case with many brands.
   / King Kutter disc is a piece of garbage #43
Spend a little more and buy a better a quality piece like Woods, Land Pride, Rhino, etc.. You spent good money on the tractor, why skmip on the implements. They take the beating.
Hope your cutter is better but don't be surprised if it isn't.
King Kutter is low quality.
I have to agree. I didn't want to spring the $1295 the dealer wanted for a Landpride landscape rake, so I looked around and found a Bush Hog brand rake for $800. After using it, I found the frame had cracked in two places, not to mention everything being lighter-duty. Bush Hog wouldn't replace the broken frame (they told the dealer to weld it - on their nickel). Too much of a pain to drag over there just for a weld job, so I fixed the cracks myself and added gussets so it won't happen again (knock on wood), BUT if I start losing lose cheepo tines...$$$$ (initial savings = false economy). I won't make that mistake again.
JayC
   / King Kutter disc is a piece of garbage #44
Re: King Kutter disc is a "MISFIT" edited
From trgo: Fast forward now to Dec. 2014
I am about to buy a 16 x 18" 3pt. disc
I am currently thinking that I will order an "Everything Attachments" box frame 16 x 18" ($1665) disc.
ETA equipment looks very nice! They build their own discs, their prices are good, and they seem like nice North Carolina folks on the phone.
I bought a King Kutter 84" rear blade last July.
What can go wrong with a blade? Not much, really!
The KK blade has a BIG made in the USA sticker! How nice!
The KK 3pt hitch bracket assembly is welded on crooked! If it had been made in China it would have likely been better built.
I did call King Kutter to complain about the workmanship, and poor paint quality. I was told: "that's the way we build em"
The 84" KK rear blade is the ONLY KK attachment that I will ever own.
I had not heard of Everything Attachments, when I bought the KK blade.
I agree with "chain Bender"!
King Kutter (KK) = JUNK !!
   / King Kutter disc is a piece of garbage #45
King Kutter is like many other companys.
on many of their attachments they offer light duty, medium duty and heavy duty.
If you only purchased the light duty option then that's what you will get. Light duty.
   / King Kutter disc is a piece of garbage #46
"Light Duty" should mean lighter weight components, not lighter weight components, poorly assembled, and poorly painted.
Bruce
   / King Kutter disc is a piece of garbage #47
The 84" blade was described in the King Kutter literature as being "Medium Duty"
Am I to understand that if I had ordered the "Heavy Duty" rear blade, the assembly would have been welded square and true, and the unpainted areas would have been properly painted?
I never considered that "Light Duty", "Medium Duty" and "Heavy Duty" would have different levels of quality control.
I am from the airline world, where "Tourist" "Business", and "First Class", ALL offer the same level of level of safety, ie: quality control.
   / King Kutter disc is a piece of garbage #48
Did you not look at the King Kutter rear blade before you bought it?
That's why I typically don't order equipment. I want to see (in the flesh) what I'm buying.
   / King Kutter disc is a piece of garbage #49
I purchased a everything attachments 7' blade. I fell for their propaganda. It is going t need to be completely rebuilt after just 6 hours of use. I regret not spend I ng the extra $$ for a bush hog brand blade. Way underbuilt.
   / King Kutter disc is a piece of garbage #50
Nearest King Kutter dealer is 200 miles away, and he did not have any King Kutter blades in stock.
I asked if he would order one, but answer was "we will order again in the fall"
I wanted to buy in May!
It seemed kinda foolish to drive 400 miles round trip, to look at a blade that the dealer did not even have.
I bought thru Amazon, but Northern Tool placed the order for Amazon, and the blade was shipped directly to me from King Kutter.
I suppose that I could have returned the blade through Amazon, but I needed to use it.
I will have the misaligned welds cut, and re-welded.
I will not need to be reminded to NEVER buy from King Kutter again.
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
TANK MANIFOLD (A55745)
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
Unused 2025 CFG Industrial XZ20R Mini Excavator (A59228)
Unused 2025 CFG...
