King of the Mountain....
   / King of the Mountain.... #21
Blake when I first saw it I also thought spreader. Then I saw the angle iron feet that keep it off the ground. Plus Junkman did mention how much weight that he adds to the box. /forums/images/graemlins/grin.gif
   / King of the Mountain.... #22
Reminds me of last winter:
   / King of the Mountain.... #23
It's a weight box. I have one on my BX2200 also.
I attached a picture. Mine is filled with sandbags.
John
   / King of the Mountain.... #24
I put mine on a dolly also. That's one of the best things I have decided to do with it when it's not in use. I have about 500 or more pounds of JD metal weights and a huge rock I found as well as small rocks too. Kind of heavy to push around but it's better than being immovable!
I did it again today........ pushed for a new record and the tractor started to go over backward until the weigh box hit the ground. Pucker factor of 10!!!! When I got off the get the camera, it settled back down on the snow... Anyone that would like to challenge this record, is welcome to it. I am not going to try this again... I want to be around for the grass cutting this summer... /forums/images/graemlins/wink.gif
Picture 2 shows how steep an angle it really is.. /forums/images/graemlins/frown.gif
Picture 3 shows the weight box touching... I have the weight box locked in the most upright position, so pushing the 3 pt handle to lower it wasn't an option. If I had the backhoe on as my counter balance, I am certain that it would have gone over for certain...
Picture 4 My tracks show were I have been....
   / King of the Mountain.... #29
I have done inclines like that also but usually in sand or gravel. I am proud that my machine can do it, but I often wonder where all the engine oil is when I have it on a shrap incline. I remember that I had an implement on the 3ph for a counter weight, spun both back wheels, then I was done cause the implement was digging in and I could not back up. Took a lot of work but I got it out.
   / King of the Mountain.... #30
Hey Junkman, take that weight box off the back of your tractor. Then you should be able to go higher. /forums/images/graemlins/smile.gif
I enjoy your posts, keep up the good work and be careful.
Ken
FORD F150 TRUCK (A54756)
FORD F150 TRUCK...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A53473)
2015 RAM 5500...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2011 JOHN DEERE 670G MOTORGRADER (A51406)
2011 JOHN DEERE...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
