Comparison Kioti CK3510 vs Kubota 3350SU
   / Kioti CK3510 vs Kubota 3350SU
Thanks for the responses so far. Both tractors have 3 range HST, looking back I see I did not say CK3510H. Actually both dealers do not stock anything but HST's in this size range, but are happy to order one for you. The Kubota has a single "rocker" type control, the Kioti one pedal for forward, one for reverse. I can see pluses and minuses to either, but am sure whichever I got used to would work fine for me.
I "fit" on both tractors just fine and both have a fairly flat area for my size 14 boots. It's close, but I think I like the way the Kioti feels a bit better, but having spent less than 15 minutes on either one, don't know that is enough to project how either will feel after an afternoon of using them.
The Kioti has a larger turning radius by about a foot, which may not be a good thing while maneuvering amongst the trees. I think it's longer as well, but since one has the measurement with the 3PH, and the other without, not sure. Ground clearance is ~1" better on the Kubota.
I've seen lots of posts on here talking about getting a dealer you like, I do like both of them for a variety of reasons. I've also read (and agree), that if you think the tractor you are looking at is going to be at the dealers often enough to worry about the drive, don't buy it. Someone posted a Dealer Survey here on TBA on outdoor power equipment including tractors and Kioti (from a dealers viewpoint) comes in a pretty close second to #1 Kubota.
Pretty darn sure both have SSQA, I specifically asked at Kioti, I think Kubota has their own QA (do they?), so not 100% on which one it had. Have read arguments regarding positioning (Kioti) vs 1/4 inching valve hydraulics (Kubota), but even after reading the threads not smart enough to know if one would work better for me than the other, or honestly how I would use either.
Given how I initially intend to use it, the only other attachment I can see is perhaps a box blade and/or some forks - the kind that just attach to the bucket, at least until I learn more about whichever one I end up buying can do. The "yard" is filled with ruts, dips and holes, enough to make me want to do something about it! Box blade the best tool for this? I am also sure that as soon as I get it and start using it, I will look for more things do to with it. The wife wants to put up a fence where the road/driveway makes a 180 Northwest of the house, and asked if I was going to buy an augur to put in the posts. Told her I would borrow/rent things like that that I cannot see using fairly regularly.
I do not personally know anyone who owns or has owned a Kioti, most of what you see around here is Kubota, with a sprinkling of most of the rest of the brands. Only one guy I work with claims to have "inside" knowledge about Kioti. (He claims to have the most valuable insight no matter what the subject though). He basically told me Kioti was junk, and stay away from them, going on to say Kioti was so bad with their dealers that they stopped selling Kiotis. Contrary to what the dealer survey showed... Reading here I can't find any major, systemic complaints about Kioti, but on the 3350 I just read the other night about an ongoing problem with Kubota and the tier 4 engine they have in it. No doubt in my mind they will solve that problem, and may already be a thing of the past. I've gotta believe they do want to keep their #1 status with their target market.
I am sure both are good companies, and will try to make things right for the end customer. I've spent some serious time in South Korea (work), and have found them to be one of the most prompt, courteous and customer service oriented peoples I've ever dealt with. I also have little doubt Kioti would be happy to replace Kubota as #1 in the market. They do build good stuff, as do the Japanese.
As to keeping this one for a long time, I know I might trade it in later, but given what I do, I only have 4 more years of current income levels so finding the closest to "perfect" size and capability tractor that will last a decade plus is important to me. Upgrading, or trading may or may not be very doable in the not too distant future.
FWIW we have 12 acres of hilly woodland like you. When I went to the Kubota dealer he asked, "Do you want to run a front-mount snowblower?" When I said no, he immediately suggested the L series.
I thought about a snowblower, sure would have come in handy last year, even handier if I had been home when it needed moved! :rolleyes:
I have a guy that "rents" a part of my shop building to run his business, his rent being, among other things snow removal. He's in the hospital right now, so it remains to be seen how it'll be this year.
I bought an L3200 which is roughly 600 lbs heavier than the B models. It was replaced by the Tier IV 3301. How the pricing works out is up to the dealers involved. the Kioti and Kubota models even look similar though there are some differences up close, like controls.
Both the Kioti dealer and the Kubota dealer when I described what I wanted to do said I was looking at the right size tractor. Unless I am looking at the wrong numbers for your tractor, both the B3350SU and the CK3510H outweigh your L3200, the Kioti by quite a bit.
In our case there are more Kubota dealers and I do find this to be a plus, as the parts guys are a wealth of knowledge.
That is a concern, but one I think I can live with.
And per above, most people are buying hydro trans for this type of use, Kioti has plenty of HST models as well.
Yeah, both dealers stock nothing else in this size, will tout the advantages and ease of use, but will order a gear model if they can't talk you out of doing it.
The Kioti is 860 pounds heavier, has almost 1/2 again the hydraulic flow (8.7 vs 11.7). Kubota lists FEL lift capacity "at lift point" as 2139 and at "24" behind lift point" as 1676 while the Kioti lists "Lift Capacity to Full Height at Pivot Pins" as 1835. I know enough from reading here that where capacities are measured would change numbers widely and will hazard a guess they are close enough to call them even - please tell me if I am even close to being right here, am a newbie and short of being called a $^#! moron, have pretty thick skin. ROPS on the Kubota folds down lower than the Kioti (a consideration where I need to park it out of the weather).
This confuses me... I think you are mixing FEL lift and 3pt lift figures. Better check these again. What transmissions are in these units.. I favor HST for this type of work. Be sure to compare HST to HST and gear to gear. We were not clear in your above, how each was equipped.
Thanks, I said I was a newbie, and wanted people to correct me when I did something dumb, thank you for doing so. I see what you mean, yes, was comparing apples to frying pans.
Kioti 3pt control is position control
Kubota 3pt control is 1/4 inching..
Kioti wins here bigtime. Position control is much better if you intend to do any dirtwork with a back blade or box blade
Glad to hear, and yes, that is one of my intended uses.
CK3510H 3pt lift 24 inches aft 1631 lbs.
3350SE 3pt lift 24 inches aft 1676 lbs
So Kubota wins by 45 lbs. Not much difference here
Kioti KL4010 loader lift to full height at pins 1835 lbs
Kubota La534a Loader Lift to full height at pins 1146 lbs
Kioti wins bigtime here. with almost 700 more lbs of lift.. That is a LOT. Night and day, and the Kioti has the heavier frame and weight to support this much more powerful loader.
Both tractors have big wide R4's. Kubota dealer said filling them would give me an additional 600#. The tires are about the same size, so I wouldn't expect to get a bunch different extra weight one way or the other. I didn't think to ask (and have no clue) if the 600# was per tire, or for the set - best guess on my part is for the set - again, correct me it I am wrong.
   / Kioti CK3510 vs Kubota 3350SU #14
Either will work well for you but the added lift capability of the Kioti is a big benefit and the hydraulic flow is better too for potential future uses. Both have good warranties and then consider financing options each offer - Kubota requires insurance with their financing - not sure about Kioti.
Several things you should consider - bundling the things you want/need in the purchase now should yield more purchasing leverage and later on they could be more - so address this financially now vs later
- Rear Blade or Box blade - for counter balance and utility - Box blade is good for driveway leveling but in the roots and rocks we have in NE a tooth bar on the bucket may be better - rear blade is good for snow and leveling - get the hydraulic tilt if you can
- Rear remote hydraulic valves - get at least one set
- Grapple - invaluable for brush clearing and clean up woods
- Bucket hooks - have them weld on three
- Loaded rear tires - for stability and added ballast
- If you envision changing out 3pt implements frequently get a quick hitch setup
- 50 hour service - see if they will include this and pickup/delivery - also this is a good time if there are any "issues" to have these resolved.
   / Kioti CK3510 vs Kubota 3350SU #15
Both the Kioti dealer and the Kubota dealer when I described what I wanted to do said I was looking at the right size tractor. Unless I am looking at the wrong numbers for your tractor, both the B3350SU and the CK3510H outweigh your L3200, the Kioti by quite a bit..
I believe the L series is a good bit heavier than the B.
My quick search
Kubota B 3350SU= 1896 lbs
Kubota L 3301= 2778 lbs
Kioti CK 3510= 2734 lbs.
I have a 2001 Kioti DK 35 (14 years and 1985 hours).
It has been great. Works good every time I use it and never gives me any problems.
My quick search
Yes, my apologies, seems I pulled the wrong tractor from Tractordata. Still, the Kioti is right in the same bleacher section of the ballpark for weight as the L3300.
   / Kioti CK3510 vs Kubota 3350SU #17
Carl made some VERY good points here. Listen to this guy:thumbsup:
The loaded rear tires will make about that 600 lbs per set. on that size machine. Well worth doing if you are going to do dirtwork.. helps out with loader work too. But don't forget rear 3pt ballast.. a Good heavy boxblade may be enough.
   / Kioti CK3510 vs Kubota 3350SU #18
I don't think either the Kioti or the Kubot come standard now with telescoping stabilizer or telescoping lower links, but either get them if you can or get a quick hitch. It will cut way down on your swear word vocabulary. :D
   / Kioti CK3510 vs Kubota 3350SU #19
Weight of B3350SU from https://steenent.com/wp-content/uploads/2014/11/B3350SU.pdf: 1,874 lbs.
Weight of L3200 (4WD HST) from 2,623.
The point I am trying to make is that dealer is pointing you at the B series. When you say, "More weight is good," you are looking at the wrong tractor series. And then you have to question why this dealer is steering you towards what probably isn't the best tractor for your needs. No skin off my nose but for almost identical requirements I got the L series.
Weight of CK3510H (4WD HST from ([url]http://www.kioti.com/products/tractors/ck10-series/ck3510h/:
) 2,734
Weight of the CK3510H is ~100# more than the L3200, so if just looking at weight, not sure what your point is here.
I looked back, because I didn't remember saying it, and see I never said "more weight is good"
Actually, on the Kubota, I told the salesman I felt the BX would be too small for what I wanted to do. I said I thought a 25-35HP range tractor would be what I needed. He's been selling Kubotas for a lot of years, people around here speak highly of him, I would have to assume he knows what he's talking about. (Then told Kioti guy what I wanted to do, and what Kubota said would be a good fit) It seems you're implying that a long time Kubota salesman at a long time and respected dealer had some nefarious purpose in mind to put me in the "wrong" sized tractor, please tell me why you would think that?
If it somehow offends you that I am considering a different tractor than you did for similar needs, like you said, no skin off my nose.
Rome TCW-20-24 (A57148)
Rome TCW-20-24...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2017 Ford F-250 Classic II Service Truck (A56858)
2017 Ford F-250...
Kubota RTV X900 (A53317)
Kubota RTV X900...
PT 500 Gallon Supply Tank (A57149)
PT 500 Gallon...
2013 Volvo BL70B (A55272)
2013 Volvo BL70B...
