Kioti DK4210 FEL won't lift and curl or drop and dump at same time
   / Kioti DK4210 FEL won't lift and curl or drop and dump at same time #21
The only thing that keeps me from being 100% convinced it is the valve is the OP stated the movement speed of the loader was slow. I would not think that it would be very slow at 9GPM.
   / Kioti DK4210 FEL won't lift and curl or drop and dump at same time #22
Again, that could be the valve.
   / Kioti DK4210 FEL won't lift and curl or drop and dump at same time #23
Agreed. Not knowing this particular system and what valve they used, I would want to do some more testing or research before spending money on a new valve for a new machine. If, by the slim chance, it is a pump issue or a priority valve problem, a new valve may not yield the results the OP is wanting.
   / Kioti DK4210 FEL won't lift and curl or drop and dump at same time #24
Too bad there isn't a simple way to get full pump gallonage output at low engine RPM. Can't imagine how it would be done other than with some type of compensating variable speed drive (electric?) on the pump. Probably would involve variable PSI output also to avoid stalling the engine at low speed.
   / Kioti DK4210 FEL won't lift and curl or drop and dump at same time #25
You can do this mechanically but it would very costly and highly inefficent. An example is the steering system on Kubota BX models. They have a single pump with a priority flow control. The priority flow control maintains steering flow regardless of the engine speed. On the BX the remaining flow is used for implements but it could be used for other functions. Still not a very efficient system.
Another way would be a large pressure comp pump with either load sense or electronic displacement. This could also provide a fixed flow over a large RPM range. Expensive large pump and controls would make this cost prohibitive for CUTs.
   / Kioti DK4210 FEL won't lift and curl or drop and dump at same time #26
Agree and agree,
simple time the cylinder stroke test back on post #19 will provide instant answers on how much flow is going to the cylinders.
   / Kioti DK4210 FEL won't lift and curl or drop and dump at same time #27
One of the variables not discussed is the OPs two choices of loaders. One “faster” and one “slower”. I assume the slower one has bigger cylinders and more lift but that’s just an assumption. I wondering out loud if that change or difference had anything to do with the issue.....probably not but I’ll ask anyway.
   / Kioti DK4210 FEL won't lift and curl or drop and dump at same time #28
Yes, do the test in post #19. A great place to start! ;)
   / Kioti DK4210 FEL won't lift and curl or drop and dump at same time #29
Curious what RPMs is the tractor at when the OP is trying to feather in two functions at once? Is 1800-2K being used for regular RPM speed for most tasks?
   / Kioti DK4210 FEL won't lift and curl or drop and dump at same time #30
If it's valved and plumbed to do two functions at once adding rpms will only speed the process. It will still have the ability at idle. Just slower.
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56438)
Case Wheels for...
2018 Chevrolet Tahoe SUV (A59231)
2018 Chevrolet...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
