Comparison Kioti Kubota or Deere. Which one to buy???????
/ Kioti Kubota or Deere. Which one to buy??????? #21
What is a quarter inching 3ph?
You have a valve that moves it up or down 1/4" at a time. In quarter inching, you don't have infinite and repeatable height settings on the 3PH as you get with "position control". Some complain that it is very hard to get a repeatable height with it. Some are OK with it. Read all about in the Kubota forums. I'm pretty sure the B2920 is quarter inching.
I'm really not planning on cutting the lawn with it. I have a scag to do that. If anything I would get a 3pt finish mower. Not a mid mount. I appreciate everyone's feedback. This is the stuff I'm looking for. Thanks for not turning this thread into a pissing match like so many thread wind up being. Does anyone have a 2920 that can comment on it digging capabilities? I've been looking for a bh in the meantime for the 2920. Looks like another 5k.
/ Kioti Kubota or Deere. Which one to buy??????? #23
If mowing is not your main job, then you want the Kioti it sounds like to me. A 2300 lb tractor is NOT an extremely heavy tractor, it is just that the others are so light. Great for the lawn, not so great for digging tasks. Don't forget you will be getting a 4 year new tractor warranty with the Kioti.
I noticed a huge increase in digging ability when I went from the Kubota L3400 to the Kioti DK35se. Both in the same horsepower class but the extra weight of the Kioti made a huge difference in the ability to dig with the FEL.
Whether position control matters to or not depends on what you do with the tractor, Box Blading or grading, it is real handy to have position control not quarter inching. Also if you mow with a mower without gauge wheels you will find that you will need to touch up your height every 15 to 20 minutes if you don't have position control as all 3pt's sag some over time and position control automatically maintains the proper position thru it's feedback mechanism.
Any of the three tractors would probably satisfy you, but it just depends on what you want to do with it as to which one is "best".
/ Kioti Kubota or Deere. Which one to buy??????? #24
If you're not planning to use the tractor for mowing, the Kioti is better in almost every way, except for one...the 2-range hydro transmission. Being new, and having a warranty is also a nice feature.
I don't care much about the whole local dealer thing...you can get parts online, and the vast majority of machines never go back to the dealer for anything.
Can I buy a rear mower with wheels on it? That way I could just drop it and cut. What rear implements need more than 22hp. For now I'm just running a tiller but you never know what I might want to buy later on. As far as the weight couldn't I just add weight to the kubota to get up to the kioti weight?
/ Kioti Kubota or Deere. Which one to buy??????? #26
You can certainly add weight to the Kubota...load the tires would make up much of the difference. I haven't exactly compared the specs on those two machines, but if they're similar size, and one is 750lbs heavier, you'd think the heavier machine would be a bit beefier in general, and that might be why the Kioti has higher 3pt and FEL lift capacities.
When I look at the FEL specs, the fact that the Kioti loader lifts 100lbs more isn't significant, but the fact that it lifts that extra weight an additional 10" is significant. That means it's significantly more powerful, and 10" can make a big difference in what you can get done. The only thing I really don't like about my LS is that the loader height is about 8-12" less than many other machines in the same size/weight/power range.
All 3pt finish mowers have wheels on them, so you do just drop and cut. Here's my finish mower...you can adjust the height of the cut by changing the spacers on the posts the tires are mounted to.
/ Kioti Kubota or Deere. Which one to buy??????? #27
Yes, rear finish mowers have adjustable gauge wheels. But rotary cutters (bush hogs, generic name)typically do not. I added some front wheels to my rotary cutter when I had the B7500 Kubota just for this reason, as the quarter inching would "sink" the 3pt after about 15 minutes and required a bump up of the lift to keep the height constant. Usually not a problem if you are lifting the rotary cutter a lot every few minutes anyway, but can be for continuous mowing. Quarter inching in not a big "problem" it is just a cheaper way of making a 3pt control. It is little things like this that set classes of machines apart, and make it difficult to compare them.:)
Isn't there stops for the lever on the quarter inching 3pt? If there is I'm not following why you can't repeat the height. Wouldn't you just raise up your implement and when you lower it go back to that stop?
One more thing is I never see used kiotis for sale in all eastern pa or northern ny. Is that saying something?
/ Kioti Kubota or Deere. Which one to buy??????? #31
. Really? Come on, man! Don't mislead a newby like that.
Please refrain from aggressive posts and comply with forum rules. In my opinion the 700 lbs is a lot in that class range.
/ Kioti Kubota or Deere. Which one to buy??????? #32
Yes, owners are satisfied with them and do not trade them in or sell them for something better
/ Kioti Kubota or Deere. Which one to buy??????? #33
It is a lot! (a lot better for most jobs)
/ Kioti Kubota or Deere. Which one to buy??????? #34
No, the quarter inching control is more like a "center off" control lever. Nudge it up and the 3 point moves up and the lever returns to center. With some you can move the lever full in one direction and when the 3 point reaches end of travel the control lever springs back to center off. There is no position stop or lock on the lever to select a position for the 3 point as there is with a "position control" 3-point.
bumper
/ Kioti Kubota or Deere. Which one to buy??????? #35
Get the 2320! I have had mine for 3 years and complete restored a house with it, cleared, built stone walls, dug trenches etc. It is a very heavy duty tractor. Very fuel efficient. No complaints. Im only selling it to get something with a bigger bucket. I love mine
/ Kioti Kubota or Deere. Which one to buy??????? #36
Someone saying you're misleading a newbie (in their opinion) is neither aggressive, nor contrary to forum terms of use. Right, wrong, or otherwise, it's his opinion, and he didn't call you names, or anything like that. I agree 700 lbs is a lot, but he doesn't...okay, that's his choice.
/ Kioti Kubota or Deere. Which one to buy??????? #37
The first part is aggressive and is against forum rules.
The second part is a directive which was uncalled for. The OP asked about the weight and people are giving him their opinions which is great. I gave him my opinion and I did not mislead anyone. I take Gittyup's post as saying that I am not telling the truth. Some people like heavier tractors, I like to add weight when I need it.
As others have mentioned if the primary purpose is to mow grass, weight is not always good and some HP is used just moving a heavier machine up hills. With loader and backhoe use weight can be an advantage for stability. Similarly larger overall dimensions help stability but can be a problem when mowing if you have tight spaces to get to. I can add weight but I can't add HP.
/ Kioti Kubota or Deere. Which one to buy??????? #38
I have a b2920 and like it a lot. try driving them all, for me the erganomics sealed the deal for kubota vs the JD. Weight isn't always useful, i find myself making the machine lighter for woods or lawn work, you do compact the soil even with these small machines. I do a lot of wood chipping and find that the pto is sufficient even for implements that require up to 30hp I don't know if kubota is conservative or what. Sounds like you aren't likely to do the BH. In case you consider one here is a thread of a big project I did in the fall with my b2920 and bh65 backhoe. http://www.tractorbynet.com/forums/projects/291945-electrical-trenching.html
/ Kioti Kubota or Deere. Which one to buy??????? #39
Go to your Dealers and get some seat time and you will know your machine. I did.
/ Kioti Kubota or Deere. Which one to buy??????? #40
Then report the post Tom.
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
2023 Ford Expedition SUV (A59231)
2023 Ford...
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
KUBOTA SR2790 SKID STEER QUICK ATTACH ROCK RAKE (A60429)
KUBOTA SR2790 SKID...
