Kioti LK3054 Flashing Voltage Dash Lamp
   / Kioti LK3054 Flashing Voltage Dash Lamp
Dave,
The parts manual I have does not show a diode in-line or a relay. I am looking for a Shop Manual for the tractor now though.
RF
   / Kioti LK3054 Flashing Voltage Dash Lamp #12
So with the new regulator installed is the voltage at the battery running still above 14.6 volts with headlights and accessories off? If so the alternator may have an internal fault that is causing it to ignore the regulator and charge all the time rather than as needed?
Rusty,
I was starting to wonder about that. I should probably pull the alt and have it tested at the auto parts store.
   / Kioti LK3054 Flashing Voltage Dash Lamp #14
It is very important that the alternator and regulator are grounded very well. I don't have access to your wiring diagram, but a lot of manufacturers run a wire that ties the reg and alt grounds together. It is so important because just a very small difference in voltage potential at the rotor (field windings) makes a large difference in the stator windings (alt output).
I don't know how far apart your alt & reg are, but if your voltmeter leads can reach from one to the other, try touching one lead to the reg case (near where it bolts to the tractor) and touch the other to the case of the alt (be sure both cases are VERY clean where you touch the leads). With the engine running, the voltmeter should read absolutely zero volts (not even a tenth of a volt) If your meter has different scales, be on the smallest scale. If you get any voltage reading at all, try using a wire in place of the voltmeter and see if it brings your charging voltage down to 13.5 to 14 volts. If it does, then check closely for bad/loose/corroded ground connections.
If the voltmeter in the above test shows zero volts, sorry, I am out of (realistic) ideas.
I suppose it could be an internal short in the alternator, but personally, I think that would be very unusual; I have never seen that, and can't visualize how that might happen. I think it would be more likely that the wire carrying voltage from the reg to the alt field is shorted to positive battery voltage somewhere (& the chances of that seem to me to be infinitesimally small)
If the alternator does have an internal short, you could remove the (probably two) small wire(s) at the alternator, and the charging voltage will remain high...I predict the alt will stop charging.
By the way...an alternator that doesn't charge will just drain your battery....one that over charges can do serious (expensive) damage.
Best of luck! Please let us know what you ultimately find.
KP
Thank you for the input.
I have not had a chance to pull the alt and have it tested.
However, I have noticed that the flashing voltage lamp also only occurs when the tractor RPM痴 are under 1900. Anything over 1900 RPM will shut the lamp off mid-flash. Not sure what it means, but I noticed the pattern.
Thx,
RF
   / Kioti LK3054 Flashing Voltage Dash Lamp #16
KP
However, I have noticed that the flashing voltage lamp also only occurs when the tractor RPMç—´ are under 1900. Anything over 1900 RPM will shut the lamp off mid-flash. Not sure what it means, but I noticed the pattern.
Thx,
RF
That really surprises me! It kinda shoots a hole in my "bad ground" theory! So, does the charging voltage actually drop above 1900 RPM??
It may take a day or so but I値l look at the output and keep you posted.
   / Kioti LK3054 Flashing Voltage Dash Lamp #18
My LK2554 has been doing the same thing for over a year now. It really doesn't bother me any so I have not worried about it at all. Like you if I turn a light on, it will stop flashing. The head lights will fluctuate brightness as the same rate the charge light does when lights are off.
I will see if I can trouble shoot mine this weekend and maybe offer a solution. Again, it really hasn't hurt anything and my battery is staying charged.
K5,
Thx. I was wondering if it would be better to ignore it, as long as my battery is not over-charging.
RF
   / Kioti LK3054 Flashing Voltage Dash Lamp #20
Have you measured the battery voltage with the new regulator?
Do it with the headlights off and then on.
Report back please.
It is possible that the dash lamp is completely independent of the regulator and is starting to fail.
Google "cub cadet voltage sensor" and do a little reading on their warning light system. It has no connection to the regulator nor alternator or dynamo.
Dave M7040
Harvest International H1072 Transport Auger (LIKE NEW) (A50775)
Harvest...
2014 INTERNATIONAL 4300 18' REEFER BOX TRUCK (A54607)
2014 INTERNATIONAL...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
2018 John Deere 325G (A47477)
2018 John Deere...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB 3 Ton Crane Service Truck (A55788)
2013 Ford F-550...
