kioti nx6010 hst cab
   / kioti nx6010 hst cab
Joe, check out the following video. I'm using linked pedal, the HST sensitivity is set halfway (straight up and down on the knob). I'm in medium range using 4WD. I'm opening my grapple just as I approach the fire and using momentum to "throw" my load into the fire as I transition from forward to back (cf. 0:50-0:60 minute mark in video for the first "toss"). You can see how fast my transitions are by also noting the engine rpm. You should have the same performance, and it can become more abrupt by dialing back the sensitivity knob.
All to say, play with the settings, but maybe something is out of adjustment that the dealer can sort out like you're thinking.
Wow, even I've never 'thrown' stuff in the fire yet with my Deere! I have 'dumped' stuff on..... Anyway, no, I am not getting that type of responsiveness, only immediately after the CAL light comes on and I have to hit it does it respond quickly. So, I've emailed the dealer to see about getting it looked at. Thanks.
   / kioti nx6010 hst cab #73
Have you gone through the whole CAL process? I've never done it, but I posted instructions from the service manual how to do it (they are a bit cryptic still). The switch should always be in the off position (as pictured) except when calibrating the HST.
   / kioti nx6010 hst cab #74
I have been experiencing the cal light coming on also I am going to try the calibration that eric just posted and see what happens.
   / kioti nx6010 hst cab #76
Darn!! I really liked the thought of smoothoperator!!!! :smiley_aafz:
Ahhh, Joe, go ahead and snap it up while it's still available. That little hiccup could have happened to anyone.
   / kioti nx6010 hst cab #77
I didn't read through everything but have noticed that if you push both HST pedals at the same time the cal light will come on for a little while and you can not operate the tractor. I need more foot swing with the Mucks on.
FYI guys I put a new thread on regarding the hydro issues. Some might find interest in it, especially NX owners.
Kap
   / kioti nx6010 hst cab #79
Seen it last night. So did they get your issue fixed?
   / kioti nx6010 hst cab #80
Here is my latest video, and my initiation into the "Eric the Oracle" Kioti damage club....:) I smashed both healight lenses, but thankfully I did not break the windshield!!
You need a set of forks. Easy to do that safely with forks. IMG_0122.jpgIMG_0123.jpgIMG_0127.jpgIMG_0133.jpg
Part of my ongoing series of lessons as to why "the right implement is more important than more horsepower".:rolleyes:
2018 Ford Explorer SUV (A56859)
2018 Ford Explorer...
2018 Autocar ACX Xpeditor T/A EZ-Pack 40 Yard Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2007 Sterling L9500 (A55973)
2007 Sterling...
UNUSED FUTURE 90 PLATE COMPACTOR (A57193)
UNUSED FUTURE 90...
Brown 8"ft Rotary Mower (A53317)
Brown 8"ft Rotary...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
