Kubota 7040 with Landmark 15 ft batwing
   / Kubota 7040 with Landmark 15 ft batwing #1
CBW
Waxahachie,Tx
Kubota 7040
batwings will not lay down after being raised to vertical
   / Kubota 7040 with Landmark 15 ft batwing #2
Check for selector above hyd port. Should be on single line in and out.
Yours is set for two line operation, I think....
   / Kubota 7040 with Landmark 15 ft batwing #3
There's no selector port on my '11 M7040. I just plug single or double acting cylinder into breakaways and raise/lower cylinders. Do you have breakaway couplers seated properly??
   / Kubota 7040 with Landmark 15 ft batwing #4
Check your "books" I think that using a single acting cyl. requires using the proper (flow) direction outlet. On one (JD) tractor I had, I had to only partially move the valve lever with the single acting cylinders to lower.
2003 Big Tex 10PI...
2012 BMW 328i Coupe (A55758)
2012 BMW 328i...
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
2017 Ford Fusion Hybrid Sedan (A55758)
2017 Ford Fusion...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
2016 Ford F250 Pick Up (A47477)
2016 Ford F250...
