OP
KEEPBALINTX
I just searched orange tractor forum and someone said that it is the nature of the hydrostatic steering to drift like this, left or right depending on which side of the road you're on. They test drove a BRAND NEW M135X and it exhibited the drifting problem. I need to try it on the left side of the road to see if it will drift in that direction too.
Jeff
Jeff
Hydraulic "drift" is rarely in the cylinder. Most likely it's within the actuator. Since it appears to be a fairly common problem, I'm guessing there's nothing that can be done. I guess you could try buying a new actuator but it'll be a LOT more expensive than the cylinder!!!
As to your cylinder question, yes it's possible for the cylinder to bypass internally. But if that were the case it would drift both directions.
