Kubota auxiliary valve.
   / Kubota auxiliary valve. #1
Stihl22
Kubota B
Hi!
I have 2010 b2320 with the factory 1 spool valve for auxiliary hydraulic on the back. The problem is that now i have more implements for my tractor and i need more hydraulic spool. A 2 or maybe a 3 spool would be great. I call kubota, they only offer a 2 spool and it was over 1k for the 2 spool valve. Is their any other option to me for maybe less expensive than the kubota option.
   / Kubota auxiliary valve. #2
Of course there is an option..
Just go to Surplus and select the number of spools you need and cut into the #80 line and use compression fittings.
Surplus Center
If your tractor is setup for a BH, you already have a place to insert the valve.
I have the factory one, there is 3 hoses that connect to the body valve. The 2 big are probably an in and out but the third tinny line I don't know what she does!
   / Kubota auxiliary valve. #4
The threes hose or ports should be IN, OUT, and PB port , but you need the PB adapter unless it is the last valve in the circuit.
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
2006 Hyundai Sonata Sedan (A55853)
2006 Hyundai...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
