Kubota auxiliary valve.
   / Kubota auxiliary valve. #1
Stihl22
Kubota B
Hi!
I have 2010 b2320 with the factory 1 spool valve for auxiliary hydraulic on the back. The problem is that now i have more implements for my tractor and i need more hydraulic spool. A 2 or maybe a 3 spool would be great. I call kubota, they only offer a 2 spool and it was over 1k for the 2 spool valve. Is their any other option to me for maybe less expensive than the kubota option.
   / Kubota auxiliary valve. #2
Of course there is an option..
Just go to Surplus and select the number of spools you need and cut into the #80 line and use compression fittings.
Surplus Center
If your tractor is setup for a BH, you already have a place to insert the valve.
I have the factory one, there is 3 hoses that connect to the body valve. The 2 big are probably an in and out but the third tinny line I don't know what she does!
   / Kubota auxiliary valve. #4
The threes hose or ports should be IN, OUT, and PB port , but you need the PB adapter unless it is the last valve in the circuit.
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2008 DRAGON 150...
2018 New Holland C227 Compact Track Loader (A55302)
2018 New Holland...
2025 Greatbear14ft Bi-Parting Gate Deer Design (A55758)
2025 Greatbear14ft...
Electric Forklift Pallet (A50322)
Electric Forklift...
MILLER THUNDERBOLT XL (A55745)
MILLER THUNDERBOLT...
2018 Ford Fusion Hybrid Sedan (A55758)
2018 Ford Fusion...
