Kubota B20 front loader doesn't lift! Why?
   / Kubota B20 front loader doesn't lift! Why?
Well I hope this is true and my pump is ok. I think the problem I am having is affecting both my powersteering and FEL.
   / Kubota B20 front loader doesn't lift! Why? #12
Hi,
Right next to the brake pedals on the transmission side is a small valve that controls the flow of hydraulic fluid to the loader. Occasionally my foot and probably yours too hits it when getting off the machine. It looks like a 3/4" bolt with a little roll pin sticking out. Mine also has a little red dot of paint on the end of the pin. It should easily turn with your fingers.
Ya, I saw that knob and I turned it both ways to try and see if that was the problem but I had no luck with that.
   / Kubota B20 front loader doesn't lift! Why? #14
If the pump didnt die theres the chance the fluid might just need to warm up a little. Are you running the SUDT fluid? If so i doubt thats the case. In my old loader I run regular cheap ol heavy fluid and when its real cold the machine has to run about a minute before the hydraulics will work.
Could also be a problem in the valve itself. If the fluid is bypassing in the valve and one of the 2 systems (steering/loader) works like a power beyond circuit; that would explain why neithers working.
   / Kubota B20 front loader doesn't lift! Why? #15
same could go for the steering valve too. Again, if either functions as a power beyond circuit and the fluid is bypassing the steering valve theres the chance the loader wouldnt work. I dont know if these work as a power beyond or not though. I'd try to find that info and it may make it easier to figure out.
   / Kubota B20 front loader doesn't lift! Why? #16
You are correct - There are 2 pumps. One for the FEL and one for the BH/3PH. Check fluid levels, filters. If all else fails remove one hose end with the tractor powered off. Move the controller. If fluid comes out then you may have a pump issue. If nothing happens you may have a clog.
2004 Delta Spread-Axle Gooseneck Trailer. 20ft+5ft. (A56438)
2004 Delta...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2020 CAT 308 (A53317)
