Kubota B7100 Questions
   / Kubota B7100 Questions #1
Shootingstar
San Jose, California, USA
Kubota B7100
Am new Kubota B7100 owner. It's an old one with manual transmission, probably 1980s.
Can someone tell me where the Serial Number is located on it? Also since it doesn't appear to be HST/GST (whatever those are) and is manual transmission, what weight gear oil is the right one? What Hydraulic oil?
Will appreciate hearing from you.
   / Kubota B7100 Questions #2
Nameplate on transmission tunnel
There is a large nameplate on top of the tunnel but it has no serial number. Maybe its too old to have a S/N on it.
   / Kubota B7100 Questions #5
You have my tractor! It's proper designation is B7100DT, the DT being for dual traction if it's 4x4. It's a B7100E if not 4x4. I bought mine at an auction about 7 years ago.
I have managed to acquire an owner's manual for the second generation B7100 -- they didn't make them between 1983 and 1990 -- which has HST. The old tractors did not have a ROPS. You can and should get one from the Kubota dealer. It will add about 150 lb. to the back end of the tractor and save your skull if you roll it -- at least if you have the seat belt on at the time.
I just use normal tractor fluid in mine. The fill is on the transmission tunnel in front of the seat. The brand is not so important as having it meet the standards in effect at the time your machine was new. I don't think any tractor hydraulic oil on the market won't do that. The loader and tranny use the same reservoir, strange as it seems with the manual box.
I use 80w gear oil in the front diff. There are grease zerks on the front wheel boxes for keeping those filled.
Among other useful things, there is an adjusting bolt under the seat to regulate the speed of the drop of the 3 point and an adjustment at the base of the steering column in the front center of the operator station to take some of the slop out of the steering if needed. You can adjust your rear wheel track by loosening the large bolt on the hex axle clamps inside the wheels and sliding the wheels in or out as needed. There is a pin that indexes the wheel in holes in the axle. Your PTO works only when the clutch pedal is out, but the tranny could be in neutral or any other gear or range. I have 3 speeds on the PTO, which I think is standard. I find the 1st one most useful for bushhog work, using it in conjunction with 2nd gear while running the engine more or less wide open. The inner pedal on the right foot rest is a differential lock. The 4wd lever is also in that area, as is the range selector, which is marked with a rabbit and a turtle on the fender.
You can use 10W-30 year round in the engine, but make sure it's labeled "heavy duty", which means suitable for diesel engines.
There are grease points and adjustments scattered all around the thing. Give it a good going over, top and bottom, with a rag to clean things off and figure out what you're looking at. Keep it oiled and greased, wash it once in a while, and it will last a long time. Mine has somewhere over 2000 hours on it (the PO disconnected the hourmeter).
It can be tippy on hills. My loader is strong enough that I can lift the unweighted rear of the tractor off the ground while trying to pick up something too heavy. A load in the bucket will tend to make it lift a hind leg while crossing downhill slopes, even with loaded tires and 120 lb of concrete on the lift arms.
The rear lift can just about pick up my Huskee 48" bush hog, which weighs about 400 lb. If I reach back and grab the top link, it will lift and hold it. I use a 72" rear blade, but the manual says it should only have a 60". The 3 pt. lift capacity is supposed to be 400 lb. at the ends of the arms. The farther back the center of mass is, the less it will lift.
I hope this has helped some. Contact your dealer and ask for a service tech who has been around a while. He'll know more about it.
   / Kubota B7100 Questions #6
If the front wheels have 4 lug nuts it is one of the older series (1983 and earlier). If it has 6 lug nuts it is a later model (1990 and up).
Tractors don't have year models like autos do. The date the tractor was sold to the original user is considered the "year model".
I had a B7100 and it was a great machine. I couldn't believe what I could do with a tractor that size. It served me well but I upgraded to a B7510 about a year ago mainly for the power steering but also because I just wanted a new tractor.
Congratulations, it will serve you well!
Bill Tolle
Fantastic, you provided a wealth of information. Thank you for taking the time to do so!
It is 4WD. I obtained an HST model owners manual with it but the information regarding the transmission and hydraulics confused me since I didn't even know what an HST is.
I want to drain and change all the lubricants so I know where I'm starting. Thus the transmission/hydraulic oil question. Do I need to buy the trans/hydraulic oil from a dealer?
I have procured a parts manual on CD and sent away for a service manual as well. Also spent hours searching the internet for info. Thats how I found this site.
The hour meter stopped at 1300 hours so I don't know what it really has. Need to fix that and the headlights. It has a new front end loader and drag box. Neither show any use.
This will be a toy primarily since I really don't have much work for it. I'm retired and needed to add a toy to my collection. :cool:
Is there a way I can communicate with you other than this media? You obviously are an excellent source for the future.
I'm in CA.
   / Kubota B7100 Questions #9
I have a 1978 Kubota B7100 gear drive/4x4 I bought new and still only 500 hours on it. My manual calls for 80w90 for all gearboxes, but a couple of years after I bought it they sent me a notice and changed the trans/rear differential to UDT. This past October I changed all of them and put 80w90 synthetic in the front differential and hubs. If you have any other questions you can PM me.
I know this is a dumb question, but what is UDT? Only available from dealer?
Does transmission, rear axle and hydraulics for front end loader all share the same oil pool?l
Is the transmission lubricant the same for the manual transmission as the HST transmission?
My sincere thanks to all of you who have helped me with my Kubota education.
   / Kubota B7100 Questions #12
The original manual for the fwd gear drive tractor calls for 12.2 qts of any of the following:
Kubota UDT
Mobil Fluid 350
Exxon Torque Fluid 56
Front Differential 0.74 qt SAE 80 Gear Oil
Left and Right Front Wheel Gear Case 0.15 qt. SAE 80 Gear Oil
Recommended change is every 300 hrs.
Two drain plugs in bottom of transmission halves.
Strainer is the large center bolt in the suction pipe of the hydraulic system
I have used Amalie All Trac 245 for the last 10 or 12 years without any problems. Since the hydraulic system uses the same fluid (all one system) and I have the FEL and hydraulic dump trailer.... when I changed the fluid to Amalie I ran the tractor for a few hours after the first change and then changed it again to try to minimize any mix of different fluids. Not sure it was necessary but for the cost of the fluid it seemed to the right thing to do. I guess the proof is in the history. 22+ years without any problems except the battery which I have changed 3 times. Filters changed of course.
I have parts and owners manual so just ask if you need anything else. My B7100 is a 1983 that I have owned since new.
I stepped up to a B3030 this past summer the new tractor is great... power steering and lots more power /forums/images/graemlins/smile.gif but I still use the B7100 for many tasks.
BandD
Just the information I was looking for. Thanks for the detail, and for spending your time to look the information up and providing it.
I'm amazed at the knowlegable helpful people on this forum.
2022 CATERPILLAR 303.5 CR EXCAVATOR (A60429)
2022 CATERPILLAR...
2017 CATERPILLAR 420F2 IT BACKHOE (A60429)
2017 CATERPILLAR...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A61307)
2012 MACK Tender...
Volvo L306 (A57148)
Volvo L306 (A57148)
2013 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2013 FREIGHTLINER...
2021 HYUNDAI ROBEX 35Z-9A EXCAVATOR (A60429)
2021 HYUNDAI ROBEX...
