Kubota BX22 Coolant Overflow Bottle Question
   / Kubota BX22 Coolant Overflow Bottle Question #1
OrangeThumb
Yorktown Heights, NY
Kubota BX22
I noticed a gash in the hose that attaches to the coolant overflow bottle on my BX22. (see attached photos, #100 on parts diagram)
Do I need to replace this hose or are they manufactured like this?
Can anyone tell me where to attach the other end, as I pulled it out inadvertently?
Thanks for your help.
   / Kubota BX22 Coolant Overflow Bottle Question #2
Just overflow hose for coolant recovery bottle, does not usually have cut in hose though. Usually routed along side bottle and radiator so it will drain to ground if it overflows. Coolant in tank should be between MAX and MIN.
David Kb7uns
Thanks for the quick reply. The coolant level is good. The hose will be easy to fix. Glad to know that I can do some tractoring today!
David Kb7uns
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1667 (A57192)
1667 (A57192)
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
