Kubota BX2200 or B7500
   / Kubota BX2200 or B7500 #41
I actually prefered the driveline and frame in the bx to the 7500.
But yes, if an engine is running 25% faster, than another performing similar tasks it seems to me it is likely to have more problems and wear out faster, leading to decreased resale value. Although I doubt many bx owners (or any tractor owner) run at full rated rpm (if only the bx had a tach), they will always be running about 25% faster at the same pto speed as the guy with the lower rated rpm machine.
   / Kubota BX2200 or B7500 #42
Hey Perry County:
I am one of those who have actually owned both a 2200 and 7500 in a short period of time. I used a 2200 for one week and returned it for the larger 7500. It was an expensive case of misjudgement, but lessons are often hard learned.
We have 30 acres of property here of which I bush hog about 15 and finish mow about 3. It is easy to make a list of pros and cons for your uses, some of the obvious factors:
The 2200 is a better finish mower with a MMM deck, but you suggest you want a rear mower? The 2200 is slightly cheaper (one hopes!). The 2200 is easier to get on and off of but that is a minor thing.
The 7500 is certainly more rugged as it is built like a full size acricultural tractor and not on a lightweight steel frame. The 7500 has better ground clearance which by numbers doesn't seem significant, but this is why I returned my 2200. The 2200 bottoms out and gets stuck frequently in heavy going (a function of low clearance and small tires). I honestly thought (at times) I was going to damage the smaller 2200 mowing in my rough spots. I was probably foolish to think I could cut 15 acres with a 2200, but I was trying to do the most I could on a certain sum of money (indeed our dealer here questioned it). I never feel this way with the 7500, and only occasionally get it stuck doing field work, and usually in soft ground while not paying attention.
The 7500 has a lower rpm engine and for continuous use it has a more comfortable feel and sound. The 7500 has adjustable rear wheels, which I move out in the summer and in for the winter. It seems to make snow removal maneuvering easier, and at the same time gives you the most stability when in the fields during summer.
I imagine the 7500 would serve you better longer. I can't remember the cost difference between the two; and now all I have is a payment book so it seems moot. Additionally, we have got a lot of snow up here in Maine, and I can't imagine plowing a lot of snow with the 2200. Here again the ground clearance is an issue. The 7500 gets stuck when I go into more than 24 inches, or so, of snow. This may not be an issue in a driveway as you can work your way through, but we move a lot of snow (on rough terrain) for the horse walks and around the barn.
Sorry to ramble on. I hope this helps. You are more than welcome to contact me at markantonfitz@aol.com if you have any thoughts or questions. I can assure you that whether you purchase a 2200 or a 7500 you are choosing the "right color." This is the topic for another discussion, but Kubota is way ahead in the compact tractor field. Good luck.
   / Kubota BX2200 or B7500 #43
"The 7500 is certainly more rugged as it is built like a full size acricultural tractor and not on a lightweight steel frame.
Actually the BX does not have a "light" pressed steel frame. The frame rails are the same thickness steel plate as on my 2410 with welded steel plate cross members and it is very stiff. Other than this, no argument. Brush hogging 15 acres with a 7500 must take a while. I do the "back" 4 with my 2410 and it is mostly broam grass and clover and that takes a while. I used to mow that area with the BX MMM because it is suspended floated smoothly over the ground but the 2410 ground contact MMM gets beat up so I switched to a cutter for it. Not realy happy with the KK cutter. I may get a rear mower with big wheels or something. J
   / Kubota BX2200 or B7500 #44
BX2200 weight = 1300
B7500HSD = 1367
Obviously the tires/wheels on the 7500 will weigh more, so unlikely the frame is "lighter" steel.
New Long Forks (A53002)
New Long Forks...
(APPROX 80) 2" X 3" X 19 3/8" ANGLE IRON (A51247)
(APPROX 80) 2" X...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
Hay Spear for Tractor (A51573)
Hay Spear for...
2021 JOHN DEERE 8R340 LOT NUMBER 209 (A53084)
2021 JOHN DEERE...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51247)
KNOW BEFORE YOU...
