Kubota BX25D / BX70?
   / Kubota BX25D / BX70? #1
Artisan
Monrovia, California
Kubota BX25
:thumbsup:
I am not sure what to label this, a BX25D or a BX70.
I see a different seat, what do you wanna bet it works better
than the BX25 seat, which I dislike. We shall see eventually.
The seat has a higher back and arm rests.
I also see a bolt on toolbox deal.
I see a BH adjustable thumb. I am not sure if I see a different
bracketry / geometry set up at the BH bucket or not...
Not sure if the BH bucket is wider than 12" or not.
Obvious sticker on FEL
What else do you see different?
   / Kubota BX25D / BX70? #2
FEL bucket looks like attachment is different, but could be the angle of shot.
I really want the specs on this puppy. What do they have the
PRV set at? I think I am looking at an 18" wide BH Bucket. If
all other parts are the same, and if they bumped the pressure
up it will be a real good indicator of what a guy could bump
his BX25 up to safely.
I took a look at Kubota's parts website and there are
2 files, BX25 AND BX25D ... I started looking for engine
and other differences.
The PRV part numbers look the same,
I see different piston numbers,
Hmmmm, what is the model number for the BH on the BX25D or BX70...
   / Kubota BX25D / BX70? #5
Brake pedal is on the left side now. The tool box is new, and on the left side. The tool box really needs to be on the right side. When exiting the operators platform, I have found that exiting from the right side is a problem, because the FEL control is in your way. When exiting from the left, with that tool box in that position, it makes your exiting more difficult.
:cool2:
OK,
Who is going to be the first to retrofit there BX25 to a BX25D w/ left hand brake pedal!
:cool2:
Why can't we just move it to the left side?
OK, what is the part number! HA!
YEP, Looks good, I do believe the seat supports are the same flavor
which means you could swap seats I do surmise...
   / Kubota BX25D / BX70? #9
Pin on bucket.
That will be a nice retrofit for mine assuming its compatible and priced right.
There was supposed to be upgraded work lights... I dont see them in that picture.
   / Kubota BX25D / BX70? #10
The seat looks like the same one on my L3240, which is more comfortable than the one on my BX2360.
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A48082)
2019 Club Car...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A50046)
2018 INTERNATIONAL...
1998 CATERPILLAR D250E OFF ROAD DUMP (A50458)
1998 CATERPILLAR...
2016 ISUZU NPR 16FT BOX TRUCK (A45679)
2016 ISUZU NPR...
2016 FREIGHTLINER CASCADIA SLEEPER TRUCK (A50046)
2016 FREIGHTLINER...
377937 (A48837)
377937 (A48837)
