Kubota fuel gauge problem
   / Kubota fuel gauge problem #1
kubotachief
PA
kubota b2910
My b2910 has a fuel gauge problem. One minute it reads full the next minute it reads empty. The tank can be full and it still will read empty sometimes, it can be empty and read full sometimes. Dealer has no clue on how to check the sending unit or gauge. I checked all wires and they seem to be tight. Does anyone know the ohm readings or an easy way to figure out what the problem is? Thanks /forums/images/graemlins/confused.gif
   / Kubota fuel gauge problem #2
My B2910 WSM says Full = 1 to 5 Ohms. 1/2 = 27.5 to 37.5 ohms Empty = 103 to 117 ohms.
Check that you Water Temp Gage is working. There is a slow blow fuse that provide voltage to both gages. If you need more info. Send my a PM with a email address. I will scan the page for you.
   / Kubota fuel gauge problem #3
Wow.. what a cruddy dealer.. Guess he don't have a phone.. nor does he have a manual to look that kind of stuff in.. hope he's good to talk to as that looks like all he's good for /forums/images/graemlins/shocked.gif
Soundguy
   / Kubota fuel gauge problem #4
I'm not familiar with your specific model but many problems like this are grounding problems. Besides the wires in the circuits the ground return paths have to be checked. With your description of the problem and what you have checked, and with the ohm values given, a return path problem is highly likely. Look for tank grounding straps and bolts that are loose. It could also be a broken wire inside the insulation. Firmly tug on all wires where they enter connectors. Check for pinched wires.
Thanks for the info. I didnt have a chance to work on it this weekend because it is in the "working mode" now. As soon as it acts up I will take some readings. Thanks for the help.
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
40ft Shipping Container (A52377)
40ft Shipping...
