Kubota HST Side-by-Side Pedal Modification
   / Kubota HST Side-by-Side Pedal Modification #81
JUst another thought here. Is the clutch on a Kubota an actual clutch or is it just a hydraulic dump. If you don't like the clutch on an hst can you not just remove the pedal? Or unhook the wires if it's just a hydraulic dump?
It is an actual clutch. Added mechanism for not benefit. It does make a mechanical break between the engine and the rest of the tractor which could be used as an emergency stop on the pto.:confused3:
   / Kubota HST Side-by-Side Pedal Modification #82
The main clutch is much larger and cheaper to replace than the pto clutch pack. Fantastic for starting large pto loads where other CUT's would not last long. Feathering the pto clutch pack not recommended, use the main clutch.
2016 CATERPILLAR 330 FL EXCAVATOR (A60429)
2016 CATERPILLAR...
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
BOX BLADE (A58214)
BOX BLADE (A58214)
2007 Case IH 275 Tractor (A59814)
2007 Case IH 275...
2018 Peterbilt 567 T/A Day Cab Truck Tractor (A60460)
2018 Peterbilt 567...
2017 VOLVO VNL TANDEM AXLE DAY CAB (A59575)
2017 VOLVO VNL...
