Kubota L4600 or Kubota L4701
   / Kubota L4600 or Kubota L4701 #1
Bond699
Sumner County, TN
None
Trying to decide which one to get?
I have a several quotes from dealers. Comparing the quotes from various places, the L4600 HST is $1,155 cheaper than the L4701 HST, both with R4 tires and the quick attach 72" FEL.
The only differences between the two models that I know of: 1) Tier level of the engine and 2) 1.5-2 more Horse power on the 4701
Would a more recent model have better resale value compared to the older model, later on?
   / Kubota L4600 or Kubota L4701 #2
The older model L4600 my have better resale value than the Tier 4 L4701.Get the SS attach bucket with either one.
   / Kubota L4600 or Kubota L4701 #3
L4600 is my pick. Simplify your life.
   / Kubota L4600 or Kubota L4701 #4
Yep, get the 4600. That's my vote anyway. While you're at it, though check out the MX series. When I was shopping, the MX 4700 was cheaper than the l4600.
   / Kubota L4600 or Kubota L4701 #5
I have a L4600 and no regrets, love the machine.
   / Kubota L4600 or Kubota L4701 #6
L4600 as well but check for a holdover MX.
Cool, thanks for the advice.
Now, the MX4700-5200--that's jumping to the Utility Tractor classification? I think the L4600/4701 is Compact Utility.
At a glance, differences seem to be a little larger, 500 pounds heavier, FEL a little more powerful. Just a little more tractor.
   / Kubota L4600 or Kubota L4701 #8
Yeah, the MX is a "utility" vs. a "compact utility" on paper. In reality they're pretty darned similar and if you can get a little more HP, little more weight, and bigger loader for the same or less $, it's worth a look.
   / Kubota L4600 or Kubota L4701 #9
Let me add that I have both an L4300 and an MX5100 and the MX is much heavier and puts a lot more power to the ground. Both are excellent tractors but the MX will out pull the L4300. The hydraulic flow on my MX is more than the L4300 too. Both are gear transmissions but I like the MX shuttle better.
   / Kubota L4600 or Kubota L4701 #10
I'd go with the L4600 over L4701.
The MX designation is a bit misleading as if you look at the specs it's really no more of a UT than the GL30 or GL40 which are CUTs; kind of a blurred line in this size. The MX has more features than the standard L Series and a really good buy though more expensive.
2013 Ford F-150 Ext. Cab Pickup Truck (A53422)
2013 Ford F-150...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
Takeuchi Skid Steer (A52377)
Takeuchi Skid...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A53843)
2017 FORD F250...
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
