Kubota L4600DT package
   / Kubota L4600DT package #11
gobluewolverine,.
May I ask what dealer you are going through?
   / Kubota L4600DT package #12
Fair price. Great rig!
I thought hard about trading my L3800DT in on a L4600DT after getting it, but the smaller tractor is doing just fine.
gobluewolverine,.
Yes, Barlow Farm Equipment
Home | Barlow Equipment
You actually build the tractor and components and put the price you want to purchase for. I actually got more equipment at a lower price. Brady Barlow is who does the negotiating and with whom I spoke with after the price was emailed to me.
   / Kubota L4600DT package #15
gobluewolverine,
For augers, look at Ford/New Holland, Deere, Bush Hog and other name brands. Ideally a brand that is carried by a dealer near you for any repair parts/ different augers.
For back hoes, again Bush Hog, Westendorf and I am sure others as well.
   / Kubota L4600DT package #16
Should be a very good tractor.. one thing you should check though. If you think you'll ever use a box blade or rear blade or boom pole, etc and will need a smooth 3 point lift, ask the dealer to put one on the tractor and try lifting it in small increments. The L4600 has been noted to have a rough lifting 3 point, the same as the rest of the L series, and some of the MX's. Yours may be fine or you won't find it a problem, but it's driven some to trade in a very short time. Kubota can't seem to fix the problem, so don't let the dealer tell you they'll "fix it after you buy".
A slip clutch shouldn't be any problem. I take the shaft off mine for the winter so it doesn't rust too badly. In the spring, loosen the bolts and spin it a few times to clean the plates up and you're good to go. I usually take mine apart every couple years to clean it. A shear bolt IS maintenance-free, but you have to replace them when they break. Depending on your mowing conditions you might never have to replace one.
Good luck, let us know how it turns out!
Sean
X2 on this
   / Kubota L4600DT package #17
One other question. Which would be the best back hoe to purchase and auger?
Just my :2cents: here. Kubota has a deal worked out with Land Pride and Land Pride makes very good implements. A PD15 or a PD25 would serve you well for a PHD. I personally would stay with a Kubota Back hoe, but that may just be me. If you plan on doing ANY finish type work using any implement on the 3pt hitch, be sure to double check that the hitch on YOUR tractor lifts smoothly at as slow as you can move the 3pt lever. Be sure to have a heavy implement hooked up when you do the test. You don't want a new tractor that starts out with a problem and then that has to be dealt with.
Sounds like you will be getting a nice rig, good luck and hope that all goes well for you. ;)
   / Kubota L4600DT package #18
I agree with all of this.
   / Kubota L4600DT package #20
I personally like the Woods backhoes. Lower price, longer warranty and seem to be well made. My local dealer told me Woods also will warranty any damage to the tractor caused by their backhoe for the first year.
Sean
2025 K4525G UNUSED Double Garage Steel Barn (A53117)
2025 K4525G UNUSED...
UNUSED AGT SDA 140W WHEEL LOADER (A52706)
UNUSED AGT SDA...
FUEL PUMP W/ NOZZLE (A53843)
FUEL PUMP W/...
1999 CASE 721C WHEEL LOADER (A53843)
1999 CASE 721C...
2017 E-Z Beever M12R Towable Brush Chipper (A51692)
2017 E-Z Beever...
2012 KENWORTH T800(INOPERABLE) (A53843)
2012 KENWORTH...
