Kubota M7030 vs Mahindra 5570
   / Kubota M7030 vs Mahindra 5570 #11
You will see allot of the good , bad and ugly when you first take a look and test drive them . Were they stored inside or outside , tires on the Kubota . Looks can sometimes be deceiving but it can also give you an idea how they were taken care of .
I have a 17 year old M5700 kubota that I keep in my garage when not in use and keep it clean , waxed etc., all maintenance done before needed and it runs like new , and looks almost new .
Do you have a place for service nearby if needed ? You shouldn't have a problem with parts if needed for the Kubota , not so sure about the Mahindra . If things don't look or test out right keep on looking .
   / Kubota M7030 vs Mahindra 5570 #12
compression test is in order, & look for fuel/ eng oil, & hyd leaks plus cond of clutch with that many hrs on the Kub
having to replace the clutch assembly could quickly eat into your savings over the Mahindra
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2020 JOHN DEERE 8R 250 LOT NUMBER 185 (A53084)
2020 JOHN DEERE 8R...
John Deere 310K Backhoe (A51573)
John Deere 310K...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2022 New Holland Powerstar 110 Tractor with Loader (A51573)
2022 New Holland...
