Kubota M7060
   / Kubota M7060 #21
The Mahindra may well outwork the Kubota, but we traded our Case CX80 with synchronized shuttle-shift and no limited slip front differential and were really surprised at how much difference it made. Now if our Case had been dependable, we wouldn't have traded for those features, but buying new, it would have been a deciding factor; often depends on what you're doing and your priorities.
In my opinion, the only thing that the Kubota has over the Mahindra is the hydraulic shuttle, and that can be a HUGE factor for some people. As far as Mahindra , both my 7520 and 3215 have given me zero dependability problems over the last 10 years. In fact the only other than std maintenance issues have been some loose power steering connections on the 7520 that were relatively easy to fix. (tighten the fitting)
   / Kubota M7060
Thanks, exactly what I want to hear.
   / Kubota M7060 #23
Please do not take what I have said as trying to get you to buy the Mahindra, I don't care one way or the other. It's just that over all, here on TBN anyway, the overall consensus (to me anyway) is that Mahindra is not built as good as some of the others. People pick this and that apart. Now part of that is because they have 4 different builders now. But trust me, EVERY brand can be nit picked for something.
You mentioned that you have studied for over a year and now sort of wish that you had just bought without researching. Really, you would not ever second guess yourself?
I researched for over 2 years before I bought the 7520. I'm glade that I did. At that moment in time, I purchased the absolute best 75hp tractor that there was, for me. I have no regrets about getting what I got. Would I get the same tractor today, no. I would prefer to have a cab at this time in my life and a few more gears for that size-weight of machine. The 12x12 trans works fine, but a 16x16 would be better. I would also bump up to 85+hp.
Good luck with your final decision. :thumbsup:
   / Kubota M7060
I appreciate any and all feedback I'm getting negative or positive. It will obviously be my final decision...and the wife's.
I may take the wife next week and let her sit on them and pick for me...that way I can blame her if I buy the wrong one. :)
As for the cab model...was seriously thinking I might do that, but I plan on being in the woods some and think I would regret the enclosed cab...but as soon as I'm in the middle of the field, I'll wish I had one.
Thanks again!
   / Kubota M7060 #25
There is no "perfect" tractor nor is there a trouble free brand that I am aware of. I have owned a Kubota M5040, synchro shift, and the only reason I gave it up was to get a larger, more powerful tractor. I agree with Brian in that the heavier Mahindra will put more power to the ground and coupled with its standard 12 speed tranny, may outwork the M7060 with its standard 8 speed gearbox (12 speed option available). The hydraulic shuttle is more than a leg saver, it is far more efficient than a standard shuttle when performing work that requires frequent direction changes.
My advice is to look at and compare all brands available within a reasonable distance. Make a list of must have features and a list of likes and dislikes about each tractor you are considering. Also consider the dealership and how you are treated. Who knows, you may even end up buying a Kioti, an LS, a Massey or another brand altogether. Have fun and enjoy the hunt.
   / Kubota M7060
Thanks coolnature!
   / Kubota M7060 #27
quik question. why are you considering both cast iron rear wheel and loaded rear tires on the kubota esp. if you are considering weight as transportation concern? imho don't need both options. also worth considering twin spindle hog options since you are on the drawing boards @ this point. a far smoother operating machine than single spindle 7' model.....just look @ pto hp requirements of each mower option (& of course weight, may be approaching max for the 7060).... much cheaper now to consider every option than to jump the gun in the buying frenzy. just go heavy duty mower (bush hog, rhino, land pride hd versions are great)if you have several yr growth.would steer clear of TSC Howse & other consumer versions, etc..... best regards
also...3" saplings is a tall task
I agree, if you are looking at a 7' singles spindle, you might as well go for an 8' dual spindle. The tractor will easily run it. And the extra weight won't be noticeable since it's closer to the tractor.
As for the weights, I use cast centers, fluid and cast weights on my M9540. Kubotas are notorious for being light in the rear.
As for saplings, I'd like to see some video of cutting 5" saplings with a 7040. A 5" sapling is wider than your hand. That's a serious tree that will be hard to "ride down". And it'll definitely shake all the dust off your tractor when you get it under the cutter......
   / Kubota M7060 #28
I have a hydraulic shuttle tractor and a mechanical shuttle tractor. The difference is huge when changing directions a lot. When running the hyd shuttle I don't think about it much,,,,,, until I get on the mechanical shuttle. I'll admit I'm a bit hard on the mechanical shuttle tractor until my brain adjusts. Huge difference in ease of use.
   / Kubota M7060 #29
just to repeat the obvious. 3" "overgrowth" is a huge challenge in a neglected field. yes, one can buy a tractor and machine that will overcome the growth. but...well, think you are attempting something that can be solved by other means with less expense/ investment/ transport, etc. maybe time for you ( & more importantly significant other) to look at what you really want & where to go from there..... it's a huge investment, just like a home. best :)
   / Kubota M7060
To be honest, I haven't measured any of the growth... I'm probably exaggerating a tad... Lots of briar, grasses approaching 4'-5' tall maybe, I've got briar up to 7-8' tall probably... Some saplings, not like my fields are full of young trees, but there are some that I could use a saw, chainsaw, or machete on instead.
I didn't know about the hydraulic vs. mechanical shuttle to be honest.
So if I understand correctly, hydraulic shuttle doesn't need the clutch to change directions, mechanical needs clutch pressed to change directions?
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2012 Volvo XC70 Wagon Sedan (A50324)
2012 Volvo XC70...
2010 FORD F150 WORK PICKUP TRUCK (A52141)
2010 FORD F150...
2006 John Deere 120C Hydraulic Excavator (A50322)
2006 John Deere...
Kivel Q.A Pallet Forks (A50121)
Kivel Q.A Pallet...
(4) 3 PLUG VALVES (A52472)
(4) 3 PLUG VALVES...
