ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 32,246
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
I didn't know about the hydraulic vs. mechanical shuttle to be honest.
So if I understand correctly, hydraulic shuttle doesn't need the clutch to change directions, mechanical needs clutch pressed to change directions?
Correct.
On my Hydraulic shuttle tractor I can change direction by simply moving the lever from "forward" to "reverse" with no pedal action. Other than if my speed is such that I choose to use the brake pedal to stop tractor movement.
On my mechanical shuttle tractor I must engage the clutch, then move the lever to change direction, again brakes applied as needed.
Sounds like such a simple thing, how hard can it be. Trust me on this, after a couple dozen direction changes it becomes HUGE.
As I said earlier, I'm a bit hard on my mechanical shuttle tractor when I first get on it, I grind a LOT of gears the first few changes!!!!
