Ok after some thinking and considering the thoughts of people here on the forum and on another forestry forum, i think i'm going to go with hydraulic. I know my tractor will be slow with the hydraulic motor. But the safety aspect, keeps me thinking. Everyone seems to think that 8000lb is enough for my tractor and after using my 3500lb electric to haul some wood this past week, i think 8000lb is more than enough. I am in the woods by myself so safety of me and the equipment is number one. Only using this for my own use and not trying to make any money using it.
So after running some number from a site i found about hydraulic motors on a motor i found available to me. I think i may be able to run around 6400lb at 33ft/min. Which if those number are somewhat correct, im find with that. Could someone with a little more hydraulic knowledge correct me if im wrong. Ill post the motor and website used for calculations below. The winch has a 4.8 in drum and 21:1 worm drive gear down.
2.2 cu. in. 4-Bolt Hydraulic Spool Valve Geroler Motor | Princess Auto
Hydraulic Motor Calculations - Womack Machine Supply Company
Okay, i dont know a big lot about hydraulics so, i could be very wrong with all of this. My tractors hydraulics are 5.15gpm @ 2205psi. So the motor above is only rated for 2030psi. So is this motor unuseable?
If so would this one work:
6.2 cu. in. 2-Bolt Hydraulic Spool Valve Geroler Motor | Princess Auto
Another question about hydraulics, if i did want to get more flow from my tractor could i run a hydraulic pump from a engine accessory belt and plumb into the current hydraulic system for increased flow?
Sorry for the long post, maybe none of this make any sense. Thanks, Nathan.
A topic about the build on a forestry forum:
http://forestryforum.com/board/index.php?topic=101602.0
