L2800 Position Control (Jerky?)
   / L2800 Position Control (Jerky?) #21
Rockyridge, I was wondering this same thing. The parts manuals I have shows the same valve used in the upgrade as the standard valve in the L3010. I'm not aware of any other valves used but I'd want to replace it with the best available option. The L3010 valve runs just under $400.
By the Work Shop Manual it doesn't look too complicate to replace but it does involve some disassembly of the 3 pt assembly and there are some references to fine adjustments to the valve. I'm wondering if the valve comes factory set or if those adjustments need to be made before installation. That's what concerns be about the job.
It would be great to hear from someone who's done it.
   / L2800 Position Control (Jerky?) #22
I can't believe Kubota went back to that valve. Economy tractor always made me mad. I paid more for this "economy" tractor than my new car in 2002!
If they say that is the way it is I would also be in the group to buy another tractor of a different color. They are absolutely useless with that jerky 3 pt. I was ready to haul mine back the first hour I tried to use my post hole auger but Kubota came through in 2005 and fixed it.
I feel sorry for the new owners to have to repeat the same old battle. I thought we early owners solved it for you. I wonder what pto clutch they are using now?
Good luck to you all, Brian
   / L2800 Position Control (Jerky?) #23
I bought a 2008 L3400 in april. The 3pt hitch was jerky at first. i just adjusted the control for the speed it lowers and since them i have not had any other problems. For some reason, kubotas 3pt hitches are very sensitive. learning how quick and responsive they are helps out alot
WOW - that's a systemic issue Kubota has with the 3pt valve. This many occurances is a serious design flaw / quality issue.
The references to Kubota justifying the issue with "economy tractor" is well quite pathetic.
I am in the middle of negotiations with a dealer on a L2800, but now am rethinking this. Why pay $15K for a tractor when it has issues and Kubota own up to and fix it.
Sounds like the 3130 valve may be a fix - but who wants to deal with that and pay for it just to get back to what should have been provided in the first place.
Well - what is the alternative - if we want a tractor about the same physical size/weight with the conventional style chassis (L series) and high quality/durability.
Is the Massey Ferguson 1528 Hydro / Gear a competitor? Sadly I think I must research the competition seriously at this point. I sure did like the orange one though!
   / L2800 Position Control (Jerky?) #25
Wow! I can believe that this jerky valve thing has resurrected!
My valve was replaced with the 3010's valve. It is a lot smoother than the original - not silk but decent. I did get the "economy tractor" line back then but they did come through with the replacement.
While I like my L3400 has not had any issues after the valve was replaced, if I were to do it again, I would, without a doubt, go with a Grand L. Theres a lot of value there for not much more money. Plus, I'd happily pay $2K or so to not have my tractor referred to as an 'economy tractor'. That said, I have absolutely no reason to trade in right now as my tractor is more than doing everything I need it to and is nearly paid off.
   / L2800 Position Control (Jerky?) #26
Kubota needs to be shot for going back to the old valves , if that is what they did .
I did got my L2800 "upgraded" to the new valve for free , thanks to a good local dealer .
Is not perfect , but much better and can be used to grade with with good results .
Keep after them , tell them , had you know that the valve was a "upgrade" when you bought the tractor you would have gotten it with the "upgraded" valve .
   / L2800 Position Control (Jerky?) #27
Unfortunately the way it goes with dealers is that you don't know if you have a good one or not until you actually run into something that needs attention ;-)
The dealer I purchased from really sucked and I never went back to them after the valve. They did take care of the valve for me - I had taken in an earlier thread on this when I went to sign the deal so even though Kubota claimed that they were going above and beyond for me, they did do it and I appreciated that. Last week I got a letter in the mail from Kubota telling me that my purchasing dealer was no longer a Kubota dealer. They still seem to be in business so I wonder what happened. My guess is that they were probably selling more lawn care / smaller stuff than tractors. Maybe Kubota too figured out that they sucked ;-).
   / L2800 Position Control (Jerky?) #28
I got my L3400 back from the dealer today with my old jerky valve still in it. They won't fix it. Said if I wanted the smooth 3ph I would have to get the Grand series tractor. I just filled out my survey that Kubota sent me. You can guess how that went. So does anyone know if there is a fix that can be done at home or am I stuck with this?
   / L2800 Position Control (Jerky?) #29
If the dealer won't help you find out who the Kubota sales rep is for your area. I had the number for the West Coast rep from three years ago but I can't find it. In my case he sent the parts directly to the dealer and instructed them to take care of it as it was a known problem.
You will probably have to go to the Kubota web site and do some digging and a few phone calls.
You don't have to accept that that is the way it is because it should not be that jerky.
Good Luck, Brian
   / L2800 Position Control (Jerky?) #30
I think i saved someone today from the same problem I am having. The UPS man delivered a package to my house today and asked me about my new tractor, said he is looking for one. I told him it is a good tractor if you don't need to use the 3 ph. I had my chipper hooked up and showed him what it did. I also told him how helpful my dealer was. I hope I saved him some grief. If anyone is interested I can try to post a video of it and you can tell me if it is as bad as the valves that were used in the past.
2004 GMC Sierra 3500 Pickup Truck (A55973)
2004 GMC Sierra...
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
2011 Toyota Prius Hatckback (A56859)
2011 Toyota Prius...
MASTERBUILT MEAT SMOKER (A58374)
MASTERBUILT MEAT...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
SHOPBUILT T/A METAL TRAILER (A52708)
SHOPBUILT T/A...
