L3130 wants to be wider
   / L3130 wants to be wider #11
It looks to me that if you unbolted the rim from the wheel, and bolted it on the center part on the other side, using the holes that are not being used at the moment, then the tire would stick out a lot further than it does now.
If you took the rim off the center of the wheel on the side in the picture, spun it around and bolted it back on, then it would also stick out further, but the tread would be backwards.
That is the way it looks to me...I assume those are four bolts holding the rim to the wheel center... /forums/images/graemlins/smile.gif
   / L3130 wants to be wider #12
Hillslider,
It looks like your wheels may be mounted in the narrowest position instead of the widest. About 59.8" edge to edge?
Trailblazer
Well that is what I am going to do. Unbolt the outer rim and swap sides. Looks kind of ugly but wider is better......unless you are talking about your date!!! /forums/images/graemlins/smirk.gif
Well.....I thought that was the widest according to other posts I have read.
But I am swapping the rims. I will let all know if it improves stability much.
   / L3130 wants to be wider #15
Do you have a need to make it that wide? I'm just thinking of all mud etc.. that could fly around since the tires are well outside the fenders.
Well....I live in West Virginia.....land of all hills. I thought about the mud slinging but I never go that fast anyway or drive on the roads.
2002 International 4300 Truck, VIN # 1HTMMAAN92H547720 (A51572)
2002 International...
2013 Yamaha YDREx4 Electric Golf Cart (A51691)
2013 Yamaha YDREx4...
2016 Ford F-550 4x4 12ft Landscape Dump Truck (A50323)
2016 Ford F-550...
2016 Chevrolet Colorado Pickup Truck (A50323)
2016 Chevrolet...
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
