L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints
   / L3200/3800/3301/3901 Rear Hydraulic Remotes Install Corrections/Hints #101
I knew that (3200).
I had a quote from Brian last year but didn't realize he had the joystick.
Do you have a pic or link of your setup?
I did try searching but it came up with a lot of unrelated hits.
Lenny
http://www.tractorbynet.com/forums/showthread.php?t=295816
Feel free to copy all you want. I made a few mistakes with fitting size & hade to get adapters. The one change I would recommend is changing the location of the QDs. I would raise them up higher or maybe put them outside the ROPS bar. Especially with a Quick Hitch it just gets to tight back there & you run into to many clearance issues. Putting the QDs further away would put them & hoses that plug into them out of harm's way.
I sold the L3200 a year ago (wanted to upgrade to a cab & HST+), but did get new TnT cylinders from Brian for my L4060. The ones from my Kubota dealer were improperly fitting leaky trash. Brian's fit perfectly when he finally got them built (warning, he has a long lead time he's up front about). I wish I had my old valves. They would show some leakdown after several days or a week. My new Kubota OEM valves show leakdown after minutes & will fully leakdown in an hour or 3. Taking it back to the dealer on this is on my to do list.
2007 LUFKIN END DUMP (A58214)
2007 LUFKIN END...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A56857)
2025 GIYI GY-SZYMJ...
2019 FORD E350 16FT BOX TRUCK (A58018)
2019 FORD E350...
2013 Ford F-150 Pickup Truck (A56858)
2013 Ford F-150...
