Price Check L3800 price check
   / L3800 price check #11
I agree that 4WD is awesome, but if this tractor will replace a 8N, then 2WD will still be fine to pull logs and brush hog.
   / L3800 price check #12
I paid 15k for my L3800DT 4wd, loaded rears, w/loader, with 14 hrs on the meter three years ago. It's a keeper!!! Believe I would shop around some more.
   / L3800 price check #13
A Kubota dealer near me has two Mx4700's 2wd. One has 27 hours and the other has 63 hours. Both are rental returns and both can be had for 14,000. I think they still qualify for new financing and I'm sure they'd throw in loading the rear tires.
   / L3800 price check
Thanks for the replies. I'll definitely be looking around some more. This gives me a good direction to start.
   / L3800 price check #15
2wd and no loader, the price should be around 12K...
   / L3800 price check #16
I've recently ran into a few problems with my L3200 in 2wd even with loaded rears.
My barn now has a pair of pallet forks sized holes in the wall in back... I figured I'd be fine on a 5-7 degree slope dropping off a maybe 200lbs metal coral panel. I have loaded rears & that panel isn't even 20% of my rated lift capacity, so I didn't bother putting on my box blade for ballast. Well apparently that was enough to leave some nice skid marks because I wasn't in 4wd.
These new CUTs are designed & balanced for 4wd, unlike the old generation which was designed for 2wd with a lot more junk in the trunk. Unless its just pulling a mower on flat ground I wouldn't want a 2wd Kubota.
   / L3800 price check #17
yep, I agree completely.
   / L3800 price check #18
If no loader (FEL), these smaller tractors are fine in just 2wd. Add a loader & I want 4wd, But counter weight on the 3 pt is even more important... ;)
   / L3800 price check
So, I got a quote on a 4x4 L3800 that was a few thousand more, and after consulting my bank account, I think I'll just look for a heavier older tractor for my bush hogging. The B2320 with fel that I have should handle the rest. Thanks for the replies. Would have been nice to get a nice shiny new tractor, but I just can't justify the cost right now for the amount of use I'll get out of it.
   / L3800 price check #20
You can get good deals on the older iron. That's the road I would take for brush hogging.
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2017 FREIGHTLINER...
SANY SY75C EXCAVATOR (A51242)
SANY SY75C...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
2017 Nissan Titan SV Crew Cab Pickup Truck (A50323)
2017 Nissan Titan...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52128)
NEW 2025 Load...
1995 KOMATSU WA320-1 WHEEL LOADER (A51242)
1995 KOMATSU...
