L3940 and L4240
   / L3940 and L4240 #1
jwalk2c
Claremont NC
Ford 1520- 1987, Deere Track Loader 455G- 1997, Wheel horse C160 x 3 , 418-8 , 314-8
Hello to all,
This my first post and please forgive me if this topic has been discussed before.
I want a tractor to replace one that a relative has let me borrow many times.
It is a NH 1920 with a Woods FEL and boxblade.
Great tractor imho.
But I want my own.
At first I had my mind set on a L3240DT , this seemed to be comparable
to the 1920 New Holland.
But I am the type of person that always thinks he has to have the most
bang for the buck ,so to speak.
I noticed when you go to a L3940 the engine is a 4cyl vs. 3cyl in the L3240.
This is about a additional $2500 dollars if I am not mistaken.
But if I am going to spend that much money I notice the L4240 is only
:rolleyes: $1500 more than L3940.
And the L4240 will accept the LA854 FEL which local dealer priced at
$4200 vs $4000 for the LA724 FEL.
The L3940 and L4240 on the dealer lot were sitting side by side and I could only find one difference, which was the front axle.
L4240 has a kingpin style knuckle with mounting on bottom and top of knuckle,please excuse me if I am not using term.
L3940 has single point mount on bottom of knuckle.
Other differences I do not know other than size of piston.
These two tractors weigh about 400 to 500lbs more than the L3240.
I want a DT transmission so that rules out L3540 and L4740.
This tractor will outlast me and will be the last one I buy.
( am still using a 1976 WheelHorse 16hp garden tractor my Dad bought new)
I am 50 and have about 10 acres of land to maintain.
Gravel drives,roads down through woods to a bottom,lots of rocks to move around,etc
I will add a bushhog latter and at some point I would like to be able to plow and disc a 2 to 3 acre garden in a soft bottom lying land.
I humbly ask for your advice to someone who has very limited experince with tractors.
Thank You Very Much
jwalk2c
   / L3940 and L4240 #2
Welcome, jwalk2c!
I'm afraid I don't know much about the 1920. Did it do everything you expect to do with the Kubota? Same size bush hog, plow, etc? If so, I suspect a similarly-sized (HP, weight) unit will do the trick.
Short of that, I have first-hand experience in buying too small initially and having to upgrade. I think the differences in the 854 and 724 loaders is lift capacity and 'heft'. I have the 853 and it is a huge difference over the 523 I used to have.
I guess my point is, go as big as you can afford now because you will constantly find new things to do with your new toy. Chippers, post-hole-diggers, bigger bush-hogs, etc. all want HP at the PTO. Piles of dirt, brush, etc. all want large loaders or box scrapers to move. Plows want traction and HP to pull them.
Good luck, and let us know what you decide - and don't forget the pictures!
-Brian
   / L3940 and L4240 #3
If money's not a big issue and you're only going to buy the one tractor, by all means, get the L4240. I'm sure the L3240 would handle the work you have planned as would the L3940, but the L4240 will do it a bit easier and quicker. Plus you'll have more flexibility for work that comes up that you currently don't foresee. Jobs you aren't even imagining now will become a consideration once you've owned the tractor awhile; new possibilities will suggest themselves every time you use it. For the unforeseen, it's better to have some extra HP on hand than too little.
All of the tractors you're considering are close to the same size; so you're not going to take a hit in maneuverability by going with the "biggest". However, if you've got tight spaces to work in or do a lot of work in the woods or around closely spaced trees, you might want to demo one of these models before you put your money down. I've found that my little B7610 can work circles around my larger L4300 in tight quarters....sometimes less is more and the B series offers a lot in a small package.
I believe the L4240 has the same 134 cu. in. 4 cylinder engine as my L4300, except direct injected. It's a smooth running, easy starting and powerful engine. Mine seems to run better and better the more I run it. Getting broke in I suppose.
If money does become an issue, take a look at the L4400. It has about the same power as the L4240 while being slightly smaller. It's more basic and only available with the 8x4 gear transmission. But since you're going DT anyway, the Grand L transmission options don't mean much.
FWIW, I'm in my early 60's and I think the money I have in my Kubotas is some of the best I've ever spent. I'm reminded everytime I use them.
Bob
   / L3940 and L4240 #4
I'm with Bob. Go as big as you can if you can afford it - unless of course you have tight spaces. In that case go big anyway and buy a little tractor for the small spaces :D
I think that the L4240 is definately worthwhile for the extra $.
Out of curiosity, why DT. Since you are looking at the grand Ls I'd definately look into GST over DT even if you are dead set against hydro. I think that hydro is the best thing since sliced bread but I think that a GST would be awesome also. That said I have not operated a DT for any length of time to become truly proficient at it.
   / L3940 and L4240 #5
Bob
Hmmm, Kubota went to direct injected on these models?
Don't worry so much about the number of cylinders in the engine. Consider other things if money playing a part in these decisions. Personally, I would have to have TnT on any tractor I own and a good heavy duty boxscraper. Those will cost you about $1500 each. The implements and attachments add up quickly and in the end, thats what your actually getting the tractor for. In my opinion, the main difference in the loaders between the tractors is the lift height. Thats something you really can't work around but lift abilities you usually can. If you will need to load dumpsters for example, the extra lift height of the larger loader will be very much appreciated. The difference in the amount of material you can move may be a couple of buckets at the end of a moving a large pile. After having owned a NH 2120, a Kubota L48 and lastly a Kubota L3830 my favorite by far was the L3830 followed by the L48 and a distant third was the NH 2120. My old International 454 with its 3 cylinder diesel was perhaps the smoothest and easily the most powerful of the group. It was the ultimate mowing tractor. It did not have a loader nor was it 4WD so it got replaced as my needs changed.
   / L3940 and L4240 #6
Good advice all, I just wanted to add that for somebody who says he has "limited experience with tractors", your eyes have picked up a lot of differences that many people might overlook. I think your instincts for what you want/need are excellent and you will buy exactly the right machine. I'll also offer a small side bet that it will end up being the bigger one.:cool:
   / L3940 and L4240 #7
I went with the L4240 precisely because that was the lowest model in the new GL lineup that offered the largest loader, the LA854.
   / L3940 and L4240 #8
VERY VERY NICE! That is one beautiful machine. Gotta love the orange! Now go get it dirty and post some more pix!
Congratulations!
-Brian
   / L3940 and L4240
Thank You All !
I do want the L4240 , but now thanks to Bob I know about the L4400.
Just one more option.
And Bob's suggestion of having a B model for a lot of tight spaces is
very logical.
I wish I could afford 2 Kubota's.
But I 'll just have to reley on my old trusty WheelHorse for small jobs :rolleyes:
_RaT_ I understand what you are you saying about a larger lifting loader capicity might just mean a few less trips to the pile.
But I am hoping the extra lift can help me with some other task.
canoetrpr you have me thinking HST:D now instead of DT.
I like to creep along in 1st gear/ range 1 on the NH 1920 and play with the loader (doing finish work and just playing like it is a big shovel) .
It has 4 ranges and 3 speeds.
I am not sure how low the low speed on the Kubuta DT trans is.
If it is faster than a :) turtle then I want be happy with it.
I have never driven HST but I think I may like it.
Does it hinder using individual braking?
A friend of mine has a B Series with HST and he says it is awkward for him when mowing downhill on a angled incline and trying to use one brake to hold the front end from sliding sideways.
Other than that he loves HST.
   / L3940 and L4240 #10
Jwalk2c,
Just my .02. I have the L4240 HST, 854 FEL, I love it. Like so many others I went two small the first time with a L2800. The 4240 is a cadillac, the quality of ride and comfort are a major step up IMHO. I don't think you can go wrong. I've owned two Kubotas and have been really impressed with both.
Good luck,
Tpevoto
   / L3940 and L4240 #11
Is it just my poor eyesight or is your loader mount missing about half the bolts at the bottom?
I just recently went and test drove a 3540 HST and I've got the fever. Waiting on a quote, trading in my L2800... :)
   / L3940 and L4240 #12
I struggled with the same thing a couple months ago. Kubota makes so many options its hard to decide. I went with the L3940 HST and so far very happy with the machine. I agree with everyone else buy the most you can afford. For me it was trying to decide if the extra 3.5 hp was worth the extra $. Sure I would like to have it, but needed to save so I could upgrade my implements etc.. I did struggle with DT vs. HST, and would buy the L4400 most likely if going with a DT model (most bang for the buck in that size). I had a L2550 before and yes I sometimes miss changing gears, however I do find myself using the HST for more things around the place because its so easy and convenient to use. I find myself not using the brake that much at all. I expect to use the brakes to help me steer some when mowing etc... Its still new to me and not sure which system (DT/HST) I prefer. Shopping for a new one is exciting. Have fun.
   / L3940 and L4240 #13
well my thoughts if you want to listen. I have had my L3240 for 3 months and I am thinking about trying to fit a L4240 into my budget. Don't get me wrong the thing is great, but I could do things faster and better with the bigger, heavier machine. If you got the L4400 you would lose 100lbs off of my machine and power is nothing if you can't put it to the ground. Now hydraulics, go grand L and you will be happier even if you don't know it. And as far as dt, I feel it is the only way to go. Good luck.
   / L3940 and L4240 #14
jwalk2c said:
Hello to all,
Great tractor imho.
But I want my own.
Thank You Very Much
jwalk2c[/QUOTE
Just alittle advice from experiences that I have had. About 5 yrs ago I purchased a L3400DT. I used it mainly to mow about 35 acres, plow my garden and do some odds and ends with the ft end loader I bought with the tractor. This little machine did it all with no problems. I also bought a 6 ft bushhog to mow with and experienced no problems. I was not, however mowing down small trees or anything like that. Well, a few yrs later I stopped by my Kubota dealer and made the mistake of visiting the lot with all the nice new tractor. Before you know it I had sold my L3400 and purchased a Grand L3940DT I sold my old tractor for about $2000 less than I paid for it. The L3940 has more bells and whistles and rides more comfortably but I only got about 4 more horsepower but it will do everything I need it to. I really liked the L3400, and being alittle smaller, could get around tight places better. With only 10 acres, this might be something to consider. It will more than adequately do what you have described you want to do and with the extra money you can go ahead and get that bushhog. No matter what model you decide on just make sure you get a loader (you can throw away your wheel barrow). I advertised in the local paper for a used 2 bottom plow and received lots of calls. Bought a used one for $25.
Hope this helps. Suggest once you make your decesion, buy it and stay away from the dealers new tractor lot for awhile.
   / L3940 and L4240 #15
   / L3940 and L4240 #16
Rat, Mentioned he would have to have...TnT ..on any of his tractors. I'm going crazy.. What is TnT ? Thanks Frank
   / L3940 and L4240 #17
Double Orange: TnT is hydraulic TOP link and hydraulic TILT. The hydraulic cylinders replace your manual screw top link and side adjuster link.
   / L3940 and L4240 #18
Thunderworks & Rat, Thanks for the information. Been scratching my head all day wondering what it was. Was planning on sliding up the K. dealer tommorrow and inquiring.[Just as good an excuse as any]. Thanks Again, Frank
2006 Acura RL Sedan (A59231)
2006 Acura RL...
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
2017 Autocar Xpeditor T/A Heil V-161 Front Loader Garbage Truck (A59230)
2017 Autocar...
2018 Ford F-550 4x4 Altec AT37G Forestry Chipper Bucket Truck (A59230)
2018 Ford F-550...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
