L4400 or MX5100 HELP!!!! cant decide which
   / L4400 or MX5100 HELP!!!! cant decide which #11
Hi Burt,
During my search for my first tractor, I had narrowed it down to the same two tractors, the L4400 and the MX5100. On May 9th, I ended up going with and purchasing the MX5100.
As other members have noted here, the extra weight of the MX5100 comes in handy. I have the Woods 720 brush hog which seems to work well with it.
The main reason I bought the MX5100 over the L4400 was the transmission. I really like how the transmission works and is set up on the MX5100 over the L4400. I only have 17 hours on mine right now but so far I have no complaints or regrets.
Good luck with your decision. Steve
   / L4400 or MX5100 HELP!!!! cant decide which #12
I'm curious, what type of tranny does the MX have? Is it a shuttle shift? Or is it a synchronized manual? If its a shuttle shift...what exactly does that mean?
   / L4400 or MX5100 HELP!!!! cant decide which #13
With a shuttle shift, you select one of say 8 gears for example. Then you have a left hand shuttle lever on the dash next to the steering column where up is forward and down is reverse.
   / L4400 or MX5100 HELP!!!! cant decide which #14
The shuttle lever for the MX5000/MX5100 is on the left of the seat next to the fender. There are a couple of types of shuttle shifts. One like on the MX5000/MX5100 is a mechanical shuttle which requires the tractor be at a full stop before shifting from forward to reverse. The other is a hydraulic shuttle and can (I am told) be shifted on the move.
   / L4400 or MX5100 HELP!!!! cant decide which #15
Yes, there are diff set-ups. My L-39 had the gear position shifter on the right and the F/R "reverser" on the left of the column.
Hydraulic is a different animal, more expensive we clutch and like you said, no clutching req'd to go from F to R. My Case backhoe has that set up.
   / L4400 or MX5100 HELP!!!! cant decide which #16
The MX5100 has a partially synchronized main gear shift on the deck (3rd and 4th) with the shuttle shift on the left hand side by the fender. The MX5100 also has the high/low shifter located right behind the forward and reverse shifter giving it 8 forward and 8 reverse gears vs. the MX 5000's 8 forward and 4 reverse (one shifter for Forward/Reverse, High/Low, with only Low in reverse). I tried out the MX5000 as well but liked the transmission set up on the MX5100 much better.
   / L4400 or MX5100 HELP!!!! cant decide which #17
I didn't get a chance to try the MX5100 when I settled on the MX5000 but, looking at the specs, I couldn't think of any use for the extra 4 high-range reverse gears. There must be something, but I continue to draw a blank.
Lower/slower reverse gears make sense. The "hang onto your hat" high-range reverse on my L4300 is about useless. Backing up is best done slowly.
Bob
   / L4400 or MX5100 HELP!!!! cant decide which #18
The shuttle on the MX5100 is synchronized so you can be rolling when you shift to and from reverse. 3rd and 4th are also synchronized as previously stated. The book recommends rolling slowly when shifting the shuttle. I've really enjoyed the 6 hours I've put on mine so far.
What do you know first post. I've been lurking for too long haha. Hello all.
   / L4400 or MX5100 HELP!!!! cant decide which #19
Bob
Well..tell us how you like it and if you got any toys to go with it:D :D :D
   / L4400 or MX5100 HELP!!!! cant decide which #20
I thought I read that the MX5100 runs it's engine at about 2700 rpm in order to get the 540 rpm PTO speed. This seems a little fast to run the engine, but perhaps it's fine or maybe I'm wrong. I'd appreciate it if any MX5100 owners could comment on this issue.
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
CATERPILLAR 255 SKID STEER (A60429)
CATERPILLAR 255...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
25ft Tag Trailer (A56436)
25ft Tag Trailer...
