LA302 FEL o-rings
   / LA302 FEL o-rings #1
John762
Tennessee
Kubota/7610
Does anyone know where to find the o-ring that is inside the quick coupler female fitting on the hoses that lead from the hydaraulic cylinders on the loader and connect to the 4 position control valve? I have tried my dealer where I bought the tractor and they could not find one on their parts diagram for that loader and they had some spares but none of them matched. The parts guy said I would probably have to buy the coupler. I told him I would look around and only do that has a last resort. I have found one in the proper diameter but thicker that would fit but not allow the coupler to completely couple. Any help would be appreciated.
John
   / LA302 FEL o-rings #2
There is nothing in the books for this by part number. We do match them.
   / LA302 FEL o-rings
can one be matched that has a chunk torn out of it? At the auto part's stores I have tried they only had something close and after 2 times neither one has worked. I have one last source to try that makes hoses and gaskets hopefully this will work. I will probably take a good one off of the other hose to try and get a better match.
john
   / LA302 FEL o-rings #5
I had the same o ring problem with my 302 fel, i was lucky and actually found a match in my junk o ring box, keep searching,there has to be a match out there somewhere.
   / LA302 FEL o-rings #6
Near my shop i have a company that sells nothing but O-rings. The owner is verrrry knowledgable. Check your phone book for industrial suppliers.
2014 Freightliner M2 106 Ambulance (A50323)
2014 Freightliner...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
1985 Ford Ltl9000 Tender Truck (A52748)
1985 Ford Ltl9000...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A52748)
2015 Ottawa Yard...
