LA302 FEL o-rings
   / LA302 FEL o-rings #1
John762
Tennessee
Kubota/7610
Does anyone know where to find the o-ring that is inside the quick coupler female fitting on the hoses that lead from the hydaraulic cylinders on the loader and connect to the 4 position control valve? I have tried my dealer where I bought the tractor and they could not find one on their parts diagram for that loader and they had some spares but none of them matched. The parts guy said I would probably have to buy the coupler. I told him I would look around and only do that has a last resort. I have found one in the proper diameter but thicker that would fit but not allow the coupler to completely couple. Any help would be appreciated.
John
   / LA302 FEL o-rings #2
There is nothing in the books for this by part number. We do match them.
   / LA302 FEL o-rings
can one be matched that has a chunk torn out of it? At the auto part's stores I have tried they only had something close and after 2 times neither one has worked. I have one last source to try that makes hoses and gaskets hopefully this will work. I will probably take a good one off of the other hose to try and get a better match.
john
   / LA302 FEL o-rings #5
I had the same o ring problem with my 302 fel, i was lucky and actually found a match in my junk o ring box, keep searching,there has to be a match out there somewhere.
   / LA302 FEL o-rings #6
Near my shop i have a company that sells nothing but O-rings. The owner is verrrry knowledgable. Check your phone book for industrial suppliers.
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A52472)
2013 KENWORTH T800...
JCB Wheel Loader (RUNS) (A50774)
JCB Wheel Loader...
2017 Ford Escape SUV (A50324)
2017 Ford Escape...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
