Land plain blade height help
   / Land plain blade height help #51
Thomas, in my neck of the (overpriced steel) woods, ar400 steel is only about 15% more per pound than mild - I redid the teeth and wear strips on my Case 24" hoe bucket 4-5 years ago, bought ar400 strips (they pre-cut them, cutting is not cheap unless you have a plasma available) - and I heated and bent/welded with 7018 as I wrapped them around the bottom of the bucket -
To give you an idea of the difference, those strips (1/4" thick) had a slight amount of rough edge, probably due to old consumables on their torch - I took a brand new 9" coarse wheel on my beastly Hitachi side grinder and started to just "soften" the edges a bit, since I already knew I would likely bump into the bucket with a shoulder now and then -
I spent about a half hour on each 36" long strip, just putting the TINIEST bevel on two edges - had it been normal mild steel, with that much grinding I would have probably needed to go get more strips :confused2:
In 4-5 years of regular abuse, I've not seen noticeable wear on the strips.
Bottom line for me - not that much more expensive than mild, only gotta do it ONCE. Now that I have a plasma, I just buy a chunk of the stuff and use it til it's gone. Saves extra cut fees, much easier and cheaper than buying hardface rod or wire, and a heck of a lot faster too... Steve
Hi Steve,
Thanks for the info, I knew there was a big difference in wearibility, but wasn't sure how much more it would cost me, or how much harder it would be to bend, though I had already figured out that cutting it wasn't within my current abilities as no plasma cutter seems likely to fall off a truck anywhere near me soon.
How hard would you estimate bending the last 6" of a 4-5" wide by 1/2" premade cutting blade up to about a 45 degree angle be using a MAP or PROPOXY torch to be?
Thanks,
Thomas
   / Land plain blade height help #52
I found this info quite helpful for helping me decide what type of road grading gear to put on my wish list - the angle tilt & pitch can be a good thing for crowning & ditching nicely. Having said that my current dragalong will not will not do the fancy angling but will do more volume of dirt. Gunna post this in a couple of places cause I think its good info.
http://roadgradingschool.com/files/ROAD_GRADING_SCHOOL.pdf
Hi again John,
It sure looks great behind your tractor, and it looks as if you'll get a lot of use out of it.
Regarding the use of hardened blades as contact material for the skids, do you think it would have been harder to bend them than it was to cut and weld them?
Also, if you had had to buy them for a nominal fee, say $50.00 per 5' section, would you still have used them as contact material?
I don't have access to free blades, so I'm trying to figure out how much difference the longer wear steel is worth there.
Thanks and G'day!
Thomas
Hi Thomas,
Hope your knee op went well. I have a guy currently doing a service and work on my dozer that is just getting over his second knee replacement. First also got infected. Good luck, hope your second goes well.
Your right with all our tracks it should get a lot of use, hopefully with out any dramas showing up my manufacturing ability.:eek:
To buy blades here the cheapest I could find was $90 for a 6' blade. I would have looked into getting something else if I had to buy them (ar400 as stated by Steve). They were not ideal as wear strips as they were wider then I needed and hard to bend (with out a press, new project comming up) but easy to cut with the oxy. I did have trouble trying to cut them with my plasma but that might have just been me though. I thought that the welded joints would not be much of a problem for wear I hope. I would diffinitely look at something that is long wearing for the skids though. I used normal mild steel for skids on my slasher when they needed replacing and they have not lasted long at all. It's a bonus sometimes when it doesn't rain much you don't have to mow much :thumbsup:
I have only had a chance to use the land plain for a few hours one morning so far and won't get to it for a few more weeks, but I will post any mods or ideas to make it work better. I was surprised that the angling back left to right by 20 degree still did not move much material along the blade, mainly just goes straight over it when it loads up. Wanting it this way to crown the road may not work as planed. Trouble there is some many variables with blade angle, pitch, tilt and depth that would all make a differance I suppose. Idealy you make one that everything adjusts but that is a huge complex job.:confused2:
   / Land plain blade height help #54
"How hard would you estimate bending the last 6" of a 4-5" wide by 1/2" premade cutting blade up to about a 45 degree angle be using a MAP or PROPOXY torch to be?"
Thomas, I would be doubtful that anything short of acetylene and a rosebud would work on that very well - maybe get away with acetylene cutting torch (keep yer thumb off the oxy lever and keep it moving along the bend line )
The other downside of that method would be that all your hardness would probably be gone at the bend, which is likely where you'd need it most. So unless you have access to a large enough forge to reheat/quench the whole blade after bending, you might not see a lot of improvement in wear characteristics.
When I heated/bent/stitch welded the wear strips on my hoe bucket, I heated them just enough to get them to bend, had a chain wrapped around bucket and strip, used a 9200 lb rated ratchet binder on the chain, lotsa tension, bit of heat, stitch weld, repeat til done (7018; ar400 wants lo hydrogen and I didn't have MIG yet) -
Since it was recommended to preheat to 3-400 by my supplier, I figured the heat to bend could double as the preheat - musta worked, 'cause they're still there :rolleyes:
You're right though, without a plaz and acetylene it's gonna cost you some labor - you dang sure aren't gonna cut AR plate with tin snips :confused: ... Steve
   / Land plain blade height help #55
Hi Thomas,
Hi John,
So far, so good, I got my staples out today, and rehab proceeds apace. They did manage to leave some extra hardened steel in my femur in the form of a lost drill/reamer bit that looks about 5/8" diameter and about 8" long on the x-rays. Hopefully it won't be any trouble in the future, but no one knows now, except that they say removing it is too difficult and possibly hazardous to attempt at present, if ever.
Thanks for the good wishes and information, I appreciate both.
Do you think that you will have to tilt the grade vis your lower arms to get it to crown?
I'm glad it seems to work well otherwise, and wondered if given your relatively low rainfall levels annually, whether crowning was so important as opposed to levelling the whoopdedos?
Thomas
   / Land plain blade height help #56
Hi Steve,
The problem then I guess is moot, because if I don't heat and bend them, nothing hardened will cover the front corner (i.e., just welding flat AR400 stock to the bottom of the runner), and if bending them will lose the hardness, then I guess cutting them and welding them like John did will also lose the temper.
Does that just leave welding on supplemental steel and hardfacing it?
Thomas
   / Land plain blade height help #57
Thomas, first of all sorry about the "no extra cost options" on your surgery - I had right shoulder rotator/complete biceps re-attachment done last year, and it was just barely manageable for several months WITHOUT any extra hardware being forgotten. wouldn't wanna think about what you're putting up with; best wishes to you.
On the hardening thing, I sometimes tend to overthink things (OK, MOST of the time) - but in retrospect, I heated, bent, stitch welded my bucket wear strips and have yet to see any signs of wear on them. From that, if I weren't such a pessimist I could conclude that I'd been worried over nothing :shocked: Not that I'd ever admit to it in public :cool: ... Steve
Hi Steve,
Thomas
Hi Thomas,
I can't believe they left a drill bit in you leg. Hope they didn't charge you extra for taking their tool.:laughing: speaking of tools how did they not know that was still there?. Does your leg rattle when you walk, how you going to explain that at the airport when you set off the metal detector?? :D Joking aside, I hope it gives you no future problem. Might be a good conversation starter though.
With regard to the runner corners, I only welded them at the back of the angle not at the front hoping that there was not enough heat to take out the temper at the front wear area. There is a small gap in the front of the joint but it is still mainly covered by the hardened steel blade section. I hope that plan works long term, I don't think I am likely to wear it out enough to worry to much about the issue.
   / Land plain blade height help #59
Hi Steve,
Thanks, but it really is only causing me a bit of having to think about what to do next. It doesn't hurt or anything, but I need to sit down with some folks from the hospital to discuss the risk of infection and whether it should get pulled out sooner or later. The perforation has me limited in how much weight I can put on the leg fpr about 6 weeks, but after that it shouldn't be any issue.
I would rather overthink (and overbuild) rather than the alternatives, but especially in the design/planning stages, there is no thought I won't entertain to try and see what I can afford and what could make it better. It's not about money til you actually start to buy materials.
   / Land plain blade height help #60
Hi Thomas,
Hi Johm,
Imagine how I felt! The issue was that it somehow detached from the extension bit that they must have had it attached to to get it up that far, and then they tried numerous methods but were unable to retreive it. Also, it isn't clear to me what they were doing that far up anywhere, unless the bit got pushed further in while they were trying to remove it. I have to go in sometime soon and, meet with my surgeon and the hospital to figure what the risks/benefit ratio of leaving it vs. removing comes down to, and then who is going toay for whatever intervention is necessary (not me I know that). I haven't seen the bill yet, but the bit better not be on there! No rattling yet, but there is a clunk when I bend and straighten my knee.
As with my parallel conversation with Steve, I hadn't considered usong hardened blade steel for the runners, but it seems such an obvious thing (now that you made it so) and I know that others have had wear issues on their runners, so if I can get some cheapish, it would maybe be a good hedge against wear.
Thanks again, and sorry for any thread-jacking I may have performed.
Thomas
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52707)
(INOP) 2016...
(2) METAL & WOOD STORAGE RACKS (A52708)
(2) METAL & WOOD...
1202 (A58374)
1202 (A58374)
BUNDLE OF 6" X 12" BUILDING PURLIN (A54757)
BUNDLE OF 6" X 12"...
Hyundai HL 960 Wheel Loader (A56857)
Hyundai HL 960...
Terms & Conditions of (Buying through EquipmentDealz Auction) Continued (A59213)
Terms & Conditions...
