land scape rake ?
/ land scape rake ? #1
idukhunt
john deere
I have been reading alot of good info on this site so I decided to sign up. I do have my 1st ? for you guys.I am going to buy a land scape rake & I narrowed it down to the woods lr72 or the Fred Cain. My ? is witch one do think is bilt better? I know the woods has a good rep but the Fred Cain looks a little stouter than lr72. Thanks for any info good or bad.
/ land scape rake ? #2
Just want to say WELCOME
Sorry can't offer anything on the rake as I am not familiar with Fred Cain.
As always the best one is a trade off on: capability vs need vs cost .
Then mix in a hole lot of opinion. It is a low service item so the dealer or seller shouldnt matter much unless you want to develope a relationship.
gg
/ land scape rake ? #3
Welcome to TBN.
I also haven't heard of Fred Cain.
Both offer almost the same,so I would go w/gut feeling.
/ land scape rake ? #4
We have a New display model 6 ft Big Bee with the square tubing beams, discounted to $450 + shipping. Paint is a little faded. Ken Sweet
/ land scape rake ? #5
Fred cain is a name brand at least here in the south i have seen it. At everything attachemets he sells some fred cain stuff, i think the field cultivators are FC.
/ land scape rake ? #6
Fred Cain equipment is good equipment. We have sold it for almost 30 years. Used to be called "Thrifty" many years ago. Ken Sweet
/ land scape rake ? #7
Woods is heavier built than most. Not familiar with Fred Cain.
/ land scape rake ? #8
The only replacement parts you might ever need will be the tines. Reasearch the replacement cost and the ease of replacement.
Do check the size, thickness and spacing of those tines on your two choices.
Do either of the rakes' tine bars reverse for finish work?
You will enjoy that attachment.
/ land scape rake ? #9
Probably the most common failure mode on a rake (not including the rake tines) is the frame supporting the rake tines, which can twist or bend. I recall one forum member posting pic's of the 5' long angle frame on his rake that he had twisted. So be sure to compare the frames with each other, the heavier, stronger looking frame might be the better choice, if the price is not out of line. Good luck!
/ land scape rake ? #10
:welcome: to TBN. I am a big Woods and Land Pride implement fan, but for landscape rakes I would prefer the Fred Cain rake just for the tubing.
Be sure to let us know which one you get and how you like it. :thumbsup:
/ land scape rake ? #11
Although I've heard good things of Fred Cain implements I've not personally seen any since they're not readily available around here. Just last year I was in the market for a landscape rake primarily for maintaining a driveway, but also for spreading/leveling dirt & gravel on other areas of the farm. My preferred ag dealer handles both Woods and Land Pride, both brands I'm familiar with and well regarded. I wound up buying a Woods medium duty with dual gauge wheels and flip down grader blade; I decided on the Woods because of the grader blade option. It's a well built heavy implement that does a very nice job on the drive. I'm very pleased with it. It wasn't cheap but I've found in the past that going the cheap route usually means disappointment and wasted money.
/ land scape rake ? #12
That Fred Caine is a very nice looking rake. I like the closed box section (square tubing) tine frame - much stiffer than angle or channel. Should help avoid a lot of the potential twisty-bendy problems Kebo mentioned.
-Jim
/ land scape rake ? #13
Although, I am a dealer for Fred Cain, The display model 6 ft Big Bee HD that I posted a picture of earlier has the same features for a lot less money. Ken Sweet
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
2025 GIDDY UP 7'X14' BLACKOUT XTREME CARGO TRAILER (A62130)
2025 GIDDY UP...
2005 KENWORTH T800 T/A 6X4 DAY CAB TRUCK TRACTOR (A59911)
2005 KENWORTH T800...
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
2015 Ford Escape SUV (A61574)
2015 Ford Escape...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 PETERBILT 579...
