Large pond silt removal
   / Large pond silt removal #22
   / Large pond silt removal #23
I would think that using some 3' high landscape fabric staked in and some hay bails would be a great filter, pump uphill and behind the fabric & hay bails...
Mark
   / Large pond silt removal #24
Now you know why DNR is hanging out, they just waiting for you to ask them to help clean out your pond :D :D :D Me bad :rolleyes:
   / Large pond silt removal #25
Jinman: sludge is pumped on shore not onto barge: these are pretty small units that I used to see. The hay bale, geotexile retention area is a good idea. I've done some cleaning in my ponds with an excavator and backhoe and had friends use a dragline where access was possible. Best results are when pond is drained and cleaned w/ dozer and excavator. If trees are not cleared back from edges you are going to have a reoccurring situation. If trees are on dike, you open yourself up to some real potential problems.
   / Large pond silt removal #26
Well, I thought of draining it but it has a few spring water sources ( one being under water ) so even if I totally drained it I don't think it would ever get dry enough to use equipment in it. Here is a google pic of my place.. Frostburg, Allegany, Maryland - Google Maps
Okay, I remember your post sometime back about your long drive :). I still say the best way is to drain and dig using machines. A good operator won't have a problem with an underground spring, they'll know how to work with and around it. Even if you use a suck method you're still going to have to get rid of VERY wet muck. I have to wonder if the suction method is so great then why are most jobs still done with excavators and dozers??
   / Large pond silt removal #27
I just checked out your mini sucker, Piranha Mini Dredges: small & compact dredges for sand, mud, & muck. I hope you have a long time to run something like that? Compare that to the bucket on a excavator, who would you place your money on for most material being moved? That little mud sucker will take a looooooong time to dredge a pond compared to even a small or mid size excavator. I believe we'd be talking months compared to days?
   / Large pond silt removal #28
The waste industry uses Vacuum tank trucks w/ hydralic dump/rear opening heads...like a presvac or vactor. I've seen a vactor pump sludge up from a waste pre-treatment settling pond. it used an 8" hose that would remove the boots of any crew member who got too close...it would vacuum up cement blocks!
Even one that does not dump can reverse the vacuum pump and discharge itself. That's what most honey dippers now use to clean septic tanks.
Years ago they used 'Marlow Mud Hog' diaphram/walking beam pumps...now if you could find one of them or rent a vacuum truck, and lower the pond it could be done.
One chemical tanker trailer cleaning station I worked at had a 'trench' drain that had a settling pit. basically a 8 foot deep, 4 ft wide by 40 foot long hole w/ a 7' tall weir near one end. the trench drain entered at the mid point and the solids accumulated behind the weir. Our vacuum truck came every 3 months and he would suck the water off and blow it out into the accumulation tank and then suck up around 5,000 gal of sludge and truck it to a landfill in Michigan.
   / Large pond silt removal #29
We had a pond that is about 1.5ac cleaned out about 2yrs ago. It had silted in so much that the water was only about 1.5' deep at the top end, maybe 5' deep at the dam.
Had the excavating company come in that originally built some of our other ponds and they did the entire job with a 40-ton excavator and two 10 wheel dump trucks. They first trenched through the dam to drain the pond, then cleaned it out hauling off the spoils to a spot in the woods about 200yds away. Installed a new stand pipe, repacked the trench, cleaned up, and they were done in 3 days. Total cost was about $2500 IIRC. The pile of soil that they left in the woods was literally larger than a two story house. This really is the only effective way to clean out a pond IMO.
Getting rid of the silt isn't an issue really. Luckily right beside my pond ( on the right side of the pic) is a hill down into the woods. and a creek . No big issue with pumping it down over the bank.
The thing with getting an excavator in here is this. I don't want the bank and grass all tore up and getting rid of the silt would mean o would need a dump truck, which translates into even more money. Also, I don't want my pond out of commission for 2-3 months while it dries out enough, of it ouw deven dry, to work it with a piece of machinery.
Also, While some ponds would be easy to drain and dry, this would would be a real pain. Not only is there an underground spring feeding it, it is also fed by yet another large spring or more like a very small stream ( on the left of the pic) that runs down into the pond and is sort of like a small wetlands. Daming this up would be pretty close to impossible.
So, since drying it would be very hard and since I have a convienient place to put the silt, pumping would not only be easier it wouldn't tie up my pond for most of the summer. My kids would not be happy for sure.
I live up on top of a mountain and our swimming season is very short to begin with. The Wife says we only have two seasons up here, winter and July 10th. .....lol..
KUBOTA L39 BACKHOE (A52705)
KUBOTA L39 BACKHOE...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
34015 (A53421)
34015 (A53421)
2015 Ford F-150 Ext. Cab Pickup Truck (A55788)
2015 Ford F-150...
2016 GMC 2500HD SERVICE TRUCK (A51406)
2016 GMC 2500HD...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A55788)
2008 Featherlite...
