Leaky loader quick connects
   / Leaky loader quick connects #1
gsgator
FL Suncoast
Branson 2910
I recently removed the FEL on my Branson 2910 to gain access for the 50 hour service. The system works pretty well to remove it. It was off for about a week and a 1/2. When I reinstalled it and hooked up the hydraulics, one of the quick connects started leaking. Do they sell the female QC's at TSC or similar stores? I am not close enough to one to just stop by.
   / Leaky loader quick connects #2
Have you tried taking it back off again and cleaning it, or re-installing several times to see if it stops. There might be "shmootz" in the way /forums/images/graemlins/grin.gif
   / Leaky loader quick connects #3
gsgator ,
I had to recently change out the o-ring in one of mine. It must have gotten pinched somehow. I just bought one at a local parts store.
   / Leaky loader quick connects #4
I also had this problem on my 3510, I just took them off and put them back on and they stopped leaking. As for tsc they do not have the qc like on our loaders. I have been looking for them to run remote lines to the rear of my tractor.
   / Leaky loader quick connects #5
I found the same problem as Big Lug when I went to reconnect my loader after taking it off to get navigate my garage a little better while hooking up my backhoe. Look in the female end of your QC coupler that is leaking and see if you can locate a small piece of rubber floating about. I am fairly confident that you just need a new O-ring. I picked up a whole pack of 10 at Lowes for under $1. A small pair of needle nose pliers will make removing and installing the O-ring a little bit easier.
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59575)
2020 INTERNATIONAL...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
