Learning How / field preparation
   / Learning How / field preparation #1
Anonymous Poster
Epic Contributor
I'd like to ask the membership for a brief(or not) "in-order" rundown of the steps/attachments needed to prepare a field/garden for planting.
I know this is born-in basic to you farm-family guys, but to a newly-retired w/20 acres, it is need-to-know stuff.
So far the only ref. of this type I have found is an old JD book...I'd like a more current slant(any book reccommendations?)
I have in mind a KISS outline...something like this (my example is just for form...PROBABLY NOT correct order!?):
1st - Mow? or Plow ( what it does, tips etc.)
2nd - Harrow (what it does, tips etc.)
3rd - pulverize or cultivate or whatever, (what it does, tips etc,)
4th - (and so-forth)
Thanks guys ( or gals:),
Larry
   / Learning How / field preparation #2
Larry, I'm sure you will get many opinions on this subject [seems as if we have lots of opinions :)], but I think the type of equipment you have will help in determining the process. There are varying types of self powered and tractor drawn implements available. What do you own?
For starters, I would prefer to apply a herbicide such as Roundup before plowing if you are starting a garden in a grassy area. It will kill the roots and save a lot of cultivating later on.
Your County Agricultural Agent might have a booklet geared to the home gardner. It will give you many tips on seed bed preparation and planting/harvesting information.
Gene,
The tractor will be a JD4700 HST (40 hp/pto).
The field implements will depend on what I learn here!
Thanks,
Larry
Maybe I should add that my 8(+/-) acres of cleared land (so-far) has been in pasture/mowed and "hayed" but the soil not "worked" for 10 years or more.
Larry
   / Learning How / field preparation #5
... hardly an expert in this field (pun intended), but it seems the amount of area to work will play a factor. If you intend to continually work the whole 8 acres you'll probably want farm type equipment (plows, discs etc.) but if you only intend to garden a portion of it a tiller may be the ticket.
Rob
   / Learning How / field preparation #6
... more thoughts...
Soil type and establishment of existing cover will be factors too. This past summer I disced about 8 of our 10 acres. It was mostly to smooth out the furrows left from previous farming. Worked really well but our soil is sandy and the weeds were only about a year old. With more established roots and/or clay soil the disc probably wouldn't have cut much. Moisture content matters too I found. Sorry no answers, just more questions...
Rob
   / Learning How / field preparation #7
Larry:
I can't say what the "right" way is but here's what I've tried.
We moved to our 3.5 Acres two years ago. The land is like yours - used to be pasture. The first spring we wanted to put in a small vegetable garden and some flower gardens so I rented a walk-behind rototiller (didn't have the tractor yet) and went to work tilling up garden plots.
Well... The grass/hay/weeds just LOVED it! And we have had to spend a MAJOR amount of effort weeding those gardens because the grass/hay/weeks came back stronger than ever!
I got the tractor in September so I have prepared a few new planting beds by first scraping up 2-3 inches of "sod" with the FEL and THEN rototilling. We'll see in the spring if 2-3 inches was enough to get "below" the weeds.
I have not had the chance to go the "Roundup" route. I'm usually working on the "Honey, I got these bulbs and I want to plant them this weekend" schedule so don't have the lead time roundup requires.
WVBill
   / Learning How / field preparation #8
LHSmith,
First how many arces are you planing to prep?
After the area been cut and clear it maybe cheaper to hire someone who already has a tiller on there tractor.
If your planing to do all the work yourself also add more on in the future you may consider purchasing a tiller.
The yesterday's years of field equipment still work fine,but take longer and the tiller the way to go. /w3tcompact/icons/wink.gif
Farming has change alot and if you can contact your local state AG department, I'm sure they can show the new and improve ways.
Thomas..NH /w3tcompact/icons/wink.gif
   / Learning How / field preparation #9
Larry, darn it, register, tell us what equipment you have, etc. and then we can help you better. But for starters . . ., when I bought my 10 acres (6 years ago), I wanted to make about a 9,000 square foot garden plot in what had been cow pasture (coastal bermuda with an assortment of weeds, etc.) Now the "real" farmers start with Roundup, but I'm hardheaded and decided I just wanted to see what I could do with no chemicals. So I just started tilling (40" Bush Hog RTS40 tiller on a B7100) and I made multiple passes. And since we were doing a lot of clearing at my brother's place and the neighbor next door, I ran many, many small limbs and lots of brush through a 5hp Craftsman chipper/shredder and tilled that in (my land is a black clay/loam). Then I went to the county agent and got the forms and containers and took soil samples and sent them for analysis (I think it cost me 10 bucks) and they said it was good, but would need nitrogen later. Then I started raising rabbits (I'm convinced that's the best fertilizer in the world). I also cleaned out a neighbor's "calf barn" that his big tractor wouldn't get into and hadn't been cleaned out in 4 years (two dump truck loads) and tilled that in. And if anyone has a more productive garden plot than mine, I haven't seen it yet.
Now I would recommend using the Roundup (unless you just want to be stubborn like me), then turn the soil with a moldboard or double buster first, followed by a tiller, to get it loosened up good and deep. Then get a soil analysis done to see what chemicals you need if you don't have access to plenty of "organic" fertilizer. This Fall I did use the turning plow, and then the tiller to cultivate a little deeper. The other thing I do is till the garden every time it rains, then gets dry enough to till (gives me a chance to play on the tractor, keeps the soil loosened up so all the moisture soaks in instead of running off, and keeps down weeds and grass - I hate those long handled tools like a hoe)./w3tcompact/icons/smile.gif
Good luck with your garden.
Bird
LOL!
Be patient with me Bird...and all you "old hands".
I'll register ( shortly!) when I HAVE some equipment to tell you about ( although I did tell someone, if you read the whole thread, what I plan to get - JD4700, ordering this week) and about my fields.
Hey, it's all you guy's fault I'm asking these [censored] questions anyway... that's what you get for being such helpful experts. Now quicherbitchin', I want to go think up some more!
Bird, your answer is just the type I was looking for... and yes, I'm stubborn, too. I'd like to try it without the poison (and maybe learn the hard-way). I've got time now, in retirement, to till those weeds to death, if thats what it takes. If I don't put a lot of hours on this tractor, I've wasted my money.
Merry Christmas, and THANKS Everybody!
Larry
Bird,
I've got a (11 hp?) Honda-powered Bearcat chipper, so I'll try the tilled-in chips idea.
I understand "moldboard", but what's a "double-buster"?
Larry
   / Learning How / field preparation #12
Aaah, Larry, the terminology sometimes changes with time and location. The "moldboard" was a "turning plow" when I was a kid (just turns the soil over - left to right on the only ones I've seen), and the "double buster" is also known in my area as a "bedder" and Tractor Supply Co. (where I got mine) calls it a "middle buster" (15" plow that cuts a furrow, throwing the dirt both directions). It's a great tool for digging the potatoes fast, but can also be used to create "hills", especially if you have a two bottom one, and even just for tearing up the ground prior to tilling or disking.
And Muhammad doesn't require that you already own a tractor to be a member here./w3tcompact/icons/wink.gif
Bird
   / Learning How / field preparation #13
<font color=blue>I'll register ( shortly!) when I HAVE some equipment to tell you about </font color=blue>
Heck, Larry -- I was a Gold member before I finally bought my tractor.
C'mon in, set a spell. /w3tcompact/icons/smile.gif
Thanks Bird..."double-buster' it is then - turns the dirt both ways!
Muhammed doesn't require a tractor for membership..right. BUT, I require a tractor, etc. to "tell you what equipment I have", no? No equipment...nothing to tell. ( I'll be tellin' you plenty, soon!)
I'd be stickin those "smiley face" things all over this stuff, but I can't make 'em work.
One more thing to learn!
Larry
   / Learning How / field preparation #15
Larry, read the "FAQs"./w3tcompact/icons/smile.gif
Bird
   / Learning How / field preparation #16
Best I can do is tell you my limited experience. 26hp 4wd CubCadet tractor. 5 1/2 acres, not all garden yet. Well drained sandy soil, had been hayed for years - pretty well compacted.
First pass with single bottom moldboard. Bought a 6' disc harrow. Ran the sh!& out of that until a weed or grass didn't DARE poke it's head up. I managed to read a short book on organic gardening and basically it said that if you have time to cultivate a lot to keep the weeds down then you can skip the roundup step. Since the garden is sill fairly reasonable size, I use a small tiller attached to my ryobi weed wacker to till between rows and plants.
Worked pretty good last year. I probably should do a soil analysis to see what else I need. My corn was disappointing and I'm told that usually means low nitrogen.
Best of luck and have fun!
   / Learning How / field preparation #17
Adding organic admendments to the soil is good. I've read that excessive amounts of wood chips will deplete the available nitrogen in the soil
   / Learning How / field preparation #18
DFB, that's one thing I'd really like to know the facts about. When I started putting wood chips on my garden, a neighbor came over and told me that would take out the nitrogen, so I'd need to add some. I've also heard that certain types of trees, or chips, would harm the garden. Well, I lost track of how much wood chips I put in there from my brother's place (oak, cedar, wild plum, hickory, and who knows what else), but then a neighbor was removing some cedars and I hauled all the stuff I could pile on a 5' x 10' trailer (16 loads) and dumped all around the garden, and eventually got it all run through the chipper. Then the crews were out here trimming trees along the power lines, and they dumped me 3 big truckloads. Of course, I did put my rabbit manure a couple of years and a couple of truckloads of old cow manure in it, too, so maybe that countered any loss of nitrogen. At any rate, I couldn't be happier with it. And I'll take all the wood chips I can get.
Bird
   / Learning How / field preparation #19
Hi Bird, kinda figured that would get a response from you. /w3tcompact/icons/smile.gif I don't write 'em, just read 'em. Like you say its nice to know what the real deal is. Fact is I've used lots of chipper material too. Composts fine especially if there is some green mixed in. Your soil certainly must be quite prosperous with all the material you've added. DFB
   / Learning How / field preparation #20
Maybe we should start a new thread on composting...
I too have heard that wood chips, lawn clippings etc. suck up nitrogen as they decompose. It does make sense to me. I wonder though, does the composting process stop at some point (it probably does)? Is there available nitrogen in fully composted material when added to a garden? I was thinking of mulching our pine trees with tree trimmer chips this spring as a weed control, but now I'm not sure that would be a good idea. Maybe I should get the chips and let them decompose for a while before I use them. Any ideas?
Rob
JOHN DEERE 9560R SCAPER SPECIAL TRACTOR (A60430)
JOHN DEERE 9560R...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2020 KENWORTH T680 SLEEPER (A59904)
2020 KENWORTH T680...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
2461 (A58376)
2461 (A58376)
2008 KOMATSU PC138USLC-8 EXCAVATOR (A60429)
2008 KOMATSU...
