whistlepig
Elite Member
Again, thanks for the thoughts.
For power, a generator is near the top of the list of things to get. Luckily, we have a 30 foot 5th wheel and we can retreat to there and run on battery/generator if we have to. I intend to tie the generator into the house at some point with a transfer switch, but maybe not right out of the gate.
Fuel is something I have given some thought to as well. Unfortunately, everything I have runs on gas, not diesel. I am not sure how I feel about storing 55 gallons of gas, but I will probably end up doing it. Maybe I will put an outbuilding somewhere away from the house. There is a gas station within about 10-15 min of there, but you pay a .10 premium.
One of the other big changes is not having city water or a well. There is a spring that feeds a 1500 gallon tank/pump (yes, there is running water), but it is truly a finite source of water. The current owner states it has never run dry, but that is just one person, and we are 4. I am going to look at the possibility of adding more storage capacity to that system. Not sure how feasible that is until I learn how much overflow there is from the current system. I assume there will be some. I have worked on other spring fed systems in the area and all the ones I have seen have an overflow for when the storage tank(s) are full. Should be as easy as tying that into another tank and making sure that water flows through both to prevent it from going stagnant in one.
I spent a good part of today engineering a rainwater collection system to gather water from around the hut and the runoff from the driveway. There is already a grate and drain at the bottom of the driveway, I just need to tie it all together. Obviously, this will not be our first choice for potable water (since it isn't), but it could be used for non potable purposes to ease the strain on the spring. I am also looking into what it would take to make that water potable. It does not look too hard, build some sand filters and such. Here is a picture of what I am thinking: http://www.siliconjunkie.net/TheHut/RunoffCollection.jpg It doesn't show in the diagram, but the sump pits and storage tank would be downhill from the level where the water is collected, so it will all be gravity fed. I will have to install a pump of some sort to make use of the water.
If worse comes to worse, we can do what many others do in the area and haul water, but I hope to avoid that.
With out water from a well or having city/county water available water would be the biggest concern. I have a friend that lives in a place that the well water is so poor (shale oil) that he tapped into a spring. He has an expensive filtering system. It works very well. Best coffee water I have ever tasted.I would not want for any better water. We have a similar filtering system on our place. To keep the iron and hard water deposits out of our bathrooms. We have a well. A good generator is a must have in the boonies. Gas is a hassle to store. It has to have stabilizer added and only good for a year. Diesel generators are much better for fuel storage. Diesel generators are very expensive. I have a Honda EB6500X gas that I am very pleased with. Worth the hassle of storing the gas.
