Leinbach aerator
/ Leinbach aerator #1
Hooked_on_HP
Coal City IL
Ford 1900 FWD Kubota F2100E
I borrowed a freinds 6' Leinbach plug core areator over the weekend. We got about 1/2" of rain on Friday night so Sat morn. I gave it a try. It about beat the tractor apart. It was only penetrating abou 1/2". The drum is full of water and I added 240# . Now it penetrated 1". I decided the ground was still to dry.It was going to rain Sat night so I decided to try again on Sun. We got 1 1/4" of rain on Sat. night, Sun. morning I tried again. Now I could penetrate about 2" but it still bounced up and down alot. I tried varrying my speed and slower was better but not as smoth as I thoufgt it shoud be. Am I doing somthing wrong or is it the design of the aerator.
Bill
/ Leinbach aerator #2
Sounds like that brand has all the tines in a horizontal row. That would give you the bounce. Most are mounted on a scroll pattern, to eliminate the bouncing. Don't know for sure? A picture of the machine would tell the tale. Ken Sweet
/ Leinbach aerator #3
I core aerate in the Spring and late Fall. Everything I have read says not to do it in the Summer because it causes your lawn to dry out too much. In the Spring I can get 6" plugs with a 50 gal drum of water on the rack.
/ Leinbach aerator
We had a extremley wet spring and early summer, then high heat. The ground has gotten packed down from mowing when the ground was soft. Now it is hard as rock. I needed to do somthing to loosen up the soil. The grass had already turned brown and died.At this point I have little to lose. I though if I could get some air to it some of the grass might come back. What brand aerator are you using.
Bill
/ Leinbach aerator #5
Don't know if it makes a big difference,but for some of those Leinbach CA's they make opptional wheel kits.Close to thirty pounds I believe.
Boone
/ Leinbach aerator #6
I live in Southern Michigan and even though we've had a lot more rain than usual this summer, I would not even get out my aerator (which is quite heavy) until after a good rain in the fall. My ground is just to hard at this point. See if you can borrow it again when the leaves are falling...
/ Leinbach aerator #7
My aerator is from James Equipment in Jackson , MO. It looks crude and doesn't have a name. It is built well. It was reasonably priced, if I remember right around $700 for a 5'. I put a frame on it to hold a 50 gal barrel on it's side. I can adjust the weight that way.
/ Leinbach aerator #8
Here is a good picture of the Scroll mount pattern on the tine mounting. This type mount doesn't bounce around as much as others. $1195 for the 5 ft. Ken Sweet
2011 CATERPILLAR TH337AG TELESCOPIC LOADER (A64279)
2011 CATERPILLAR...
2012 INTERNATIONAL LA677 4X2 S/A DAY CAB TRUCK (A59911)
2012 INTERNATIONAL...
2023 BOBCAT T66 R-SERIES SKID STEER (A64279)
2023 BOBCAT T66...
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
1787 (A64280)
1787 (A64280)
2019 WABASH DVLSHPC 53X102 T/A DRY VAN TRAILER (A59912)
2019 WABASH...
