Dave M7040
Elite Member
- Joined
- Dec 10, 2012
- Messages
- 2,749
- Location
- Williamstown Ontario Canada
- Tractor
- Kubota M7040 Nuffield 465
I tried adding one at a time until I could no longer fit any more shims in it Dave-no change in pressure-still 1900lbs.I think I am just going to order a new pump.
Mike
Mike
Before deciding you need a new pump, why not test the old one in place.
First, you never want to cut off the output of the pump completely because to do so will destroy it.
Disconnect the pump from the valve below using the quick coupler.
Install a Tee on the pump outlet with your new gauge in one leg of the tee.
On the open end of the tee, install a hydraulic valve, not a water valve but the same style as an outside faucett, one where you can choke the flow slowly. Run the outlet of that valve back into the tractor or even a bucket for this very short test
With the tractor running slowly, restrict the flow out of the pump with the valve watching your pressure gauge. It will increase in pressure. Don't go over the 2,500 psi you have been told is the normal limit.
Don't pump all the oil out of the tractor and run the pump dry. 33 liters per minute is a lot of oil!
If you see 2,500psi out of the old pump, buying a new pump is not going to solve anything except slim your wallet.
Dave M7040
