lets talk water towers
   / lets talk water towers #31
To keep the water in the tank from growing things you can always treat with swimming pool chlorine. In a constant low dose it is safe and kills everything. You can get a float dispenser with chlorine pucks. Set it on the lowest setting and place in the tank. You would probably get a few weeks out of it before needing a puck refill.
Mine lasts a week in my hot tub and the hot water really drives up the chlorine consumption.
I use the same chlorine to clean/sterilize my RV water tanks.
I would go with a tank and pump. Forget the tower idea.
I use a caged 300 gallon tank to water my trees around the farm. I got the tank for $25 from a local potato processing plant (they make french fries and need an anti-foaming agent on the water conveyor belts). The chemical was food grade so I wouldn't have any concerns of using it for drinking water.
A water tank doesn't have children swimming in it with all the grass clippings and dirt they bring in on their feet or perspiration and p##. A lot less chlorine would be needed if any.:)
   / lets talk water towers #33
Yup, I use a small small amount. About 1 tsp for 30 gallons in my RV holding tank.
   / lets talk water towers #34
Yes, if you do not need a gravity feed system, there is less cost, less
maintenance and less liability by just having another cistern tank available
to fill during the spring or fall. Since you are not there during the week,
something could easily happen to the tower tank full of water whether
diliberately or not, just causing another project when you planned on
relaxing all weekend.
Might seem paranoid but not being there all week i would feel better with the water protected inside the building where critters or others can't get to it.
   / lets talk water towers #35
JetBoat - Sounds good, looks like you've just about got it all sorted. With all the effort you're going to & expense of concealing the tank, it sounds like the cabin is for the long term, as such 500gal still sounds real small to me so suggest maybe you check your usuage calc's maybe go for a min.1000gal as it won't work out that much more expensive & you're going to a lot of trouble. Also whatever tank you end up with, suggest you plumb an overflow pipe well away from your stand/shed installation as any seepage in your absence/over to time could compromise the stand/structure/similar concern if you're not intending to install gutter/downpipes on the tank shed.
Txdon - Interesting you're considering a metal tank, you don't see them much over here any more (except a few in some metro areas as "country features" in gardens) as poly superceded them many years ago. If you have strongly mineralised &/or high salt soil (an indication if you're unsure is black steel star posts rusting quickly or gal wire/fence posts oxidizing quickly) I'd be real cautious of installing a metal tank(gal or s/steel ) as even from roof water you will accumulate corrosive sediment in the tank which may play havoc with the seams. The other thing is any scratch on the base will be first thing to corrode over time.
Also, I would only be looking at solar if there are no other options for a small irrigation set up like yours.
Water Sanitation Solutions ? The inline Ozone Sterilisers work pretty good, but I have only used for bore water combined with charcoal micro fiters &/or Zelbrite type sand filter. Don't know what your ground water is like over there, but as our tanks are all rain water we have never had any need to sterilise or treat, it's pure with no additives (though as a precaution we test all tanks every 6months to make sure there's no bacteria/contaminants).
Chlorine, Iodine & all the chemical muck is pretty much a waste of time as it won't kill/remove the stuff that can really hurt you like E.coli, Giardia, Cryptosporidium, Campylobacter which need some pretty trick filters to remove (I've installed only one of these ever on one of our farmhouses, only because the farmhands kid has a low immunity condition).
If you want clean drinking water with as low risk as practical , two basic rules:-
a) make certain your water is not subject to any contamination by Bird, Bat, Rat, Mouse, Frog & especially Snail faeces.
b) & without fail install a "Waterboy" type suction hose float inside the tank for your pump or gravity fed to draw from, basically this is a floating suction line inside the tank ( Waterboy is a brand name which your tank supplier may know), allows your water to always be sourced from the cleanest source from the top of the water level in the tank The WaterBoy - Tank Water
Canada-CT230 - The c.300gal caged pallecons are great for farm use & I use them too all the time, but there's no way I'd be using them for drinking water. There's a reason there cheap second hand, they've outlived their commercial life as "food grade" & the plastic isn't UV stabilsed (that's why they go brittle after few years in the sun) & it breaks down/bleeds impurities, contaminants & toxins into the water, including BPA's NRDC: Plastic Water Bottles -- Is "BPA-free" the Same as Safe?
   / lets talk water towers #36
I'm considering metal because of the algae in my dark green poly tank, it seem light still gets through. More importantly, I just like the way the metal tank looks and the tank will be in a very visible place. I have used a solar pump for garden applications and have a pump and solar panel that work good together.
   / lets talk water towers #37
can you get a metal shell? and still use a poly tank? I like the look of the metal.
   / lets talk water towers #38
Txdon -If there's algae in your poly tank, it's probably due to 2 factors, remove 1 or preferably both & you're cured it:-
a) Light, rather than coming thru your tank, a small amount of light is probably entering thru gaps on a manhole cover or perhaps via your inlet gutter down pipe (paint it black or a dark colour 2-3' before it enters the tank), prompting algae in smaller tank(less than c.500gal) in constistently higher ambient tempartures.
b) Water Quality- more likely the roof water you're capturing is very high in nutrients such as nitrogen &/or phosphates ( could be air polution, could be neighbours fertilzing their lawn..etc settling on your roof), easiest solution is to install/build a first flush diverter to stop contaminents Superhead Rainwater Filter and First Flush Diverter
To clean/kill the algae already in a poly tank only (do not use on other tanks), clean with:-
a) Not suitable for Human or Sheep drinking water - Add Copper Sulphate
To do this, mix thoroughly 1 ounce of copper sulphate in 1 pint of water in a container, then gradually add 7.5 tablespoons/c.4onces of the prepared solution to each 1,000 gallons of water & mix/agitate as thoroughly as possble (use you pump to recirculate) Leave this mix in the tank for a week, whilst this water can be used for crop spraying, irrigation and livestock watering, excluding sheep - personally I've always then flushed the tank out with clean water.
b) Drinking Water
From the various cleaners available, in a small poly tank, the easiest way is to use a non-scented food grade bleach (you'll find lots of laundry bleaches in the supermarket are actally labelled as food grade) mix into a very weak c.0.5% solution to get rid of the algae.
No other product should be used unless it is approved food grade, powdered/liquid swimming pool chlorine is not food grade & can contain very unhealthy trace elements/impurities
c) Irrigation Only
Take a sample to your pool shop, they'll most likely recommend a heap of stuff, you'll only need the chlorine in their recommended dosage which is fine for irrigation use only.
Agreed, the metal tanks look much better & have that "rustic" appeal, just not practical now in commercial farming.
Great if your solar pump works out, usually the inexpensive ones are challenged in high head applications c. 30'+ because of the pump loading/current draw.
   / lets talk water towers #39
Now that's something I will look into. Thanks.
MBTRAC, Thanks for all the good information. I do have a first water down tube but it is manually opened to clean. I can let it drip and open the gate valve completely if it becomes clogged. Thanks for the link and the information on copper sulfate.
If you use chlorine or copper sulfate in the water to treat the algae and then use it to water a vegetable garden will the vegetables still be organic?
   / lets talk water towers #40
I have thought about a silo with a plastic liner or tank in the top
I drive by an old barn with a concrete panel and tie rod silo on the way to work and just dream of how to get down and it to my off grid cabin 200 miles away.
Presently I use a 1250 gallon in ground cistern with a rv pump pulling from it and a 450 ft well with a low yield with pump and inverter pumping 2X a day till flow stops.
We collect rain water for the toilet flushing and I use some pool tablets in it to keep it clear.
tom
Ambulance (A52377)
Ambulance (A52377)
2015 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
2018 Seal Rite SR 700XP Seal Trailer (A52384)
2018 Seal Rite SR...
2011 Chevrolet Camaro Convertible Coupe (A52377)
2011 Chevrolet...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
