rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,662
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Heres the specs I mentioned
OK then, looking at those specs we can tell you a lot about your machine. Turn to the second sheet first, because it only has a couple of pieces of information that we need. and they apply to the 3pt hitch, not the front end loader (FEL). First of all that second sheet tells us that yours is a L2501 gear drive 4wd - which I had missed before. And then we go down to the hydraulic section... By The Way, that hydraulic section only applies to the 3pt hitch, not the FEL. And all we care about in that infor is the pressure - which we see is modest (and deliberately limited) at 2205 psi . And then we go up to the lift at " 24" behind the lift points". The lift points are where the implement is connected, and 24" is about where the center of gravity of the implement will be located if it is a simple short implement like a back blade. For the 3pt hitch only, the manufacturer will normally limit the pressure and the lift capactity of the 3pt hitch so that trying to lift something too heavy won't cause the tractor to do a wheelie. From the spec sheet, it says you can lift about 1389 lbs of back blade. Since your typical 6 or 7 foot wide cat 1 back blade only weighs a few hundred pounds you have lots of additional to spare. And that's good, because something like a box blade is not only heavier but it's center of gravity tends to be farther away from the tractor. So the manufacturer gave you enough force to handle a nice heavy implement back there.
BTW, it is cheap and easy for a manufacturer to make the 3pt hitch very, very powerful - so strong that it could damage the tractor. And It is common for them to build in a pressure limiting valve to deliberately reduce the rear lift to a safe level for that tractor. Looking at that 2205 psi number for the pressure tells me that is what the manufacturer has done. The normal gear drive type hydraulic pump used in these tractors will generate a lot more pressure than that if it is not limited.
After some coffee I'll interpret that first sheet for you. It's all about the Front End Loader and is more important for what you are doing. Hope this all helps.
rScotty
