Avenger
Veteran Member
As the days start to shorten, and the nights seem to get longer, I find myself using my lights more and more. However, I have noticed a problem with these lights. They are spot lights! Which, in of itself, is fine, except they have a portion of the lens that faces directly, 90ー, from the beam of light. Since the beams work better at a slight angle toward the ground, so I can see what I am doing, this little bit of light (which is a lot of light) seems to point directly into the cab, against the glass, effectively illuminating the dirt on the glass, and making visibility near impossible. Even when the glass is clean, the reflection of this light is too great.
I am in need of better lights for my cab tractor. Not looking to break the bank, and would prefer something in the LED spectrum that is bright, but in the directions I need (back into the cab not being one of them), and is more or less plug-n-play (though not required).
Any help with this? Has anyone (or everyone) changed out their lights to something better?
I have yet to try duct tape on the lights. I would rather change them out than go down that route.
Thanks in advance!
Thanks in advance!
