LIQUID TIRE BALLAST - WHAT FLUID TO CHOOSE
   / LIQUID TIRE BALLAST - WHAT FLUID TO CHOOSE #51
Maybe I should plant beets and run through my Jack Lalane juicer :)
   / LIQUID TIRE BALLAST - WHAT FLUID TO CHOOSE #53
Funny. lol.
It would give you inexpensive weight for your tractor AND reduce your own weight at the same time if you drink that healthy stuff :)
But then there would be a counterbalance too . . In Western WI the counties use it as a pre spray when icy conditons are expected . . . likely not at RimGuard pricing . . but better than corn or beans :)
   / LIQUID TIRE BALLAST - WHAT FLUID TO CHOOSE #54
   / LIQUID TIRE BALLAST - WHAT FLUID TO CHOOSE #55
Not especially relevant, but I checked at the local Lowes (I need some WWF, anyway- World Wildlife Fund??) but it wasn't $0.79 but $1.97. Ouch.
Axlehub's comment about summer stuff makes sense- I'd be checking it before I bought 80 bottles, too.
   / LIQUID TIRE BALLAST - WHAT FLUID TO CHOOSE #56
Yeah it would have to be -20 to be safe. The SKU and ad claim -20 though.
AxleHub:
I am sure that you can buy RimGuard in Western Wiscosin for your $2.50 price.
Problem is; not everybody lives in Western Wisconsin.
I called two Rimguard dealers, and that is how I arrived at the $450+ price
$3.23 per gal. plus 6.25% sales tax, plus $75 per tire to install (dealer quoted numbers) plus my cost to drive 170 miles round trip - to the closer of the two dealers.
It would be 1400+ miles for me to drive to Western Wisconsin to buy RimGuard.
That is a bit too far for me!
   / LIQUID TIRE BALLAST - WHAT FLUID TO CHOOSE #58
AxleHub:
Greetings fried,
My post was not about western wi pricing BUT it was an example that rimguard is not a set price and it needs some detail and determination to achieve apples and apples comparison.
1. I contacted a total of 5 rimguard providers. My 4th contact was the highest and my 5th contact was the cheapest. I got 4 of the 5 names/numbers directly from rimguard. Their website encourages you to email them for dealer locations and to answer your questions. I assume you contacted them early on and they gave you the two names you have. My point is more effort may reward you.
2. 2 of the 5 I contacted would sell me the rimguard directly so I could self install at my location (1 of the 2 was my 5th and cheapest contact). Again, buying www from lowes and hauling it home and self installing doesn't fairly compare to rimguard with dealer installation included. Your time and effort has a value and both products would require similar tools and efforts.
All I'm saying is, if rimguard only gave you 2 names to check . . You're being short changed in your efforts. And lets not forget that 30% more weight is like getting 30 % more product too for your calculations.
Your decision doesn't impact me at all and you are certainly welcome to doing whatever you desire . . . but public message boards like this one allow us all to be teachers and examples to those who don't post.
3. Just be aware that in self installing the www to save money . . that option will require a level of safety that rimguard will not require. You can get splashed with rimguard or bathe in it and you'll just get messy. But if the same thing would happen with the www, you could (I didn't say "would") end up going to walk-in at the local clinic/hospital as my friend did when they worked with a similar component found in www.
Lastly, I think it would be great for you to come to WI and see what our area has to offer . . but rimguard pricing probably isn't enough to justify it :)
AxleHub:
I lived South of Minneapolis (Lakeville) from 1967 thru 1990, so am VERY familiar with your area (had friends in Eau Claire).
My daughter and her family live in Woodbury, Mn., but I get out there very seldom.
My life is split Spring thru Fall, between Cape Cod, and Nova Scotia (tractors live on Cape Cod), Winter in Florida.
At my age, it is the best that I can do.
Will pick up my completely repainted 1988 Ford 1920 FEL today. It looks like NEW!
   / LIQUID TIRE BALLAST - WHAT FLUID TO CHOOSE #60
Another thing to note, regardless of the fluid you use, you should replace rubber stems with the metal variety. I've seen several posts on forums that rim guard dissolved the internal cement on valve stems after 5 years or so, causing messy leaks. The rim guard site warns against this too, and says it can happen with any type of fluid. They say it is due to lower quality tubes and valve stems these days. It would be worth the upgrade when you fill, rather than a repair later.
Heavy Duty D-Ring Shackles (A55852)
Heavy Duty D-Ring...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55315)
PENDING SELLER...
24634 (A55853)
24634 (A55853)
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
