Loaded Tires on a Bx
   / Loaded Tires on a Bx #21
Yup, I know that. Valve on top and I get a mix of air and washer fluid out. But I put in 10 gallons of fluid in them and it was still all air so I added almost a gallon of water too.
I just found another thread here that said 75% on a 26x12x12 holds 10 gallons. It was quoted from the Goodyear Farm Tire Handbook. I bought my 20 jugs of washer fluid after reading a reference here from Firestone.
   / Loaded Tires on a Bx #22
Don't want to bust your bubble, but thats only about a total of 200 pounds, total.
I don't see any improvement here.
   / Loaded Tires on a Bx #23
It may not sound like much but 200lbs on a 1400lbs machine is 14%.
   / Loaded Tires on a Bx #24
Loading the rear tires was enough for my hoe to take a bite where as before, it would lift the tractor.
Also made it less tippy on the hill I had to traverse.
   / Loaded Tires on a Bx #25
I can attest, the extra 200lbs makes a significant difference. Much more stable on slopes and better traction when using the FEL.
   / Loaded Tires on a Bx #26
I too can attest it makes all the difference in the world too loading those tiny rear tires.
   / Loaded Tires on a Bx #27
Yes. It is also 200 lbs down low. You can't get weight much lower than that. Does a lot to the stability of the machine.
   / Loaded Tires on a Bx #28
Rimguard said I needed air/liquid (metal) valve stems... assuming the BX2360 has rubber ones or not?
   / Loaded Tires on a Bx #29
Rimguard told me 8.9 gallons on the 26x12-12 turf FYI...
   / Loaded Tires on a Bx #30
From what I've read here several times from our colleagues 75% is enough to keep the rim submerged and generally if you press the valve in withit set at 12 oclock you will get fluid back out but it will likely spit some air as well. That's where mine are right now with over 10 gallons. I don't know whose manual is correct but they obviously don't agree.
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
2020 Mathieu MC210 Azura Flex Street Sweeper (A55851)
2020 Mathieu MC210...
10ft Enclosed Cargo Trailer (A53424)
10ft Enclosed...
2016 Chevrolet Malibu Sedan (A55853)
2016 Chevrolet...
