Loading car on trailer
   / Loading car on trailer #11
This is mildly off-topic but involves my NH tractor so I thought it might be the place to post it.
I've got a car that needs to get loaded on a trailer (a guy is buying it from me). The car weighs 2800 pounds and can't be driven up onto the ramp as the engine is dead.
Don't have a winch but was hoping to use my NH TC45 to do pull it up onto the trailer somehow. Hadn't done this before and wanted to get some advice from those more experienced and wiser than I.
Should I be able to pull it up onto the trailer? If so, how would you do it?
Thanks!
Matt
My first thought would be a come-a-long on the front with the tractor behind for pushing, gently, with the front end loader or pallet forks.
Now. I'll shut up and see what the experts say. :D
   / Loading car on trailer #12
If this is one of those newer cars with plastic bumpers I am betting that the bumper comes off before the car goes on.:D
   / Loading car on trailer #13
Thanks for all the ideas.
Funniest one was sent to me via e-mail:
"Fix the car, drive it up on the trailer."
Now, why didn't *I* think of that? ;-)
Naw, you just need a bigger tractor so that you can pick up the car and slide the trailer under it! :)
   / Loading car on trailer #14
Leave it hooked to the truck and park it jack knifed 45 degree's.
Cable, chain or rope tow it up.
   / Loading car on trailer #15
Is the car a stick ? If it is not disassembled, pull the plugs, disconnect the fuel pump, put it in first gear, engage the clutch and let the starter power it up into position. With no compression, you may be surprised how far it will run on the starter. Drop in a fully charged battery and pull it once it is parked on the trailer.
   / Loading car on trailer #16
The "hey y'all wachiss" method would be to leave the trailer attached to the towing vehicle. Run a big long tow strap from the front axle of the busted car over the front of the trailer and back under the trailer and below the busted car. Hook onto it with a tractor and pull so the car rolls up onto the trailer as the tractor drives away. Be sure to take a video of it so we can all watch on YouTube or America's Funniest Home Videos.:D:D:D
   / Loading car on trailer #17
Can't top Jim's suggestion but why not park the trailer in to a ditch and push the car right on to the trailer, what remains the difficult task is how to get the trailer out of the ditch:D.
I think probably the safest thing to do it is to have trailer attached to your towing vehicle and using an electric winch to pull the car up. I'll have driver in the car so he can at least apply the hand break or have the car in first gear with the clutch pressed (if manual shift) to have some option if the winch cable decides to break. I'd control the winch as far as I can since I hate to get whiplashed by a busted cable. Might use a combination of winch and a chain to keep the whiplash to a minimum if it should occur.
JC,
   / Loading car on trailer #18
Jinman...that would work....think about it, might sound convuluted but I see no reason it wouldn't work. So would jack knifing the trailer and pulling it on with a tractor as another poster suggested...
   / Loading car on trailer #19
Ah heck, you don't even need a tractor for that - instead of the tractor, tie the end of the rope to a tree, then just drive the tow vehicle ahead... ;)
   / Loading car on trailer #20
BeeferMan, are you sure you weren't born in the South?:rolleyes::D
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
SCAN TO RECEIVE TEXT UPDATES (A60430)
SCAN TO RECEIVE...
FENCE PANELS (A58214)
2012 KOMATSU PC360LC-10 EXCAVATOR (A60429)
2012 KOMATSU...
1968 Oliver Model 1850 2WD Tractor (A56438)
1968 Oliver Model...
Case 950 8 Row Air Planter (A56438)
Case 950 8 Row Air...
