log splitter pump leaking. HELP!!!
/ log splitter pump leaking. HELP!!! #11
I had a suction tube that was loose. To expand the tube I found a socket that when forced inside increased the O.D. just enough to get good press fit again.
/ log splitter pump leaking. HELP!!! #12
No number, but I can ask again. The blue I looked up mentioned up to 3/4 in tube, so I added that in my post.
This is the one that sounds relative, especially about seal and lock up to 3/4 in . This is used before assembly
Loctite Threadlocker Blue 242 from Loctite Adhesives
Threadlockers from Loctite Products | Threadlocking / Mechanical Gasketing | Loctite Adhesives
I have emailed another request to Haldex.
The Green 290 that someone mentioned is for after assembly.
Loctite Threadlocker Green 290 from Loctite Adhesives
This one also might be relevant, and before assembly, and is good up to 1 in.
Loctite Threadlocker Red 271 from Loctite Adhesives
thanks JJ,
Henkel/Loctite has such a wide assortment of products it would be great if Haldex would specify what they use. Help reduce some of the guessing.
Roy
/ log splitter pump leaking. HELP!!! #13
To remove old Loctite, I believe they use LOCTITE 768 X-NMS cleaner/desolver
/ log splitter pump leaking. HELP!!! #14
I had the same problem with a power steering pump on a VW.
I removed the nipple, cleaned and slightly reworked to provide a tighter fit then lightly sanded to enhance the bond and used red Loctite 271, end of problem.
I would recommended 271 as it is high strength and should be a permanent fix.
Loctite at one time made a green product that was used for stud and bearing mounts.
It was recommended for loose bearing fits such as a bearing race that spun in it痴 bore or in your case securing a nipple.
It appears that they expanded the applications of their green product.
Tim
New Quick Attach Hay Spear (A61166)
New Quick Attach...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
The Owner Corporation 3314 (A60463)
The Owner...
1998 INTERNATIONAL 9400 (A58214)
1998 INTERNATIONAL...
2017 Nissan Quest Van (A61569)
2017 Nissan Quest...
1997 John Deere 5300 (A60462)
1997 John Deere...
