Log splitter with lift table and 4 way wedge
   / Log splitter with lift table and 4 way wedge
Finally got it painted.
   / Log splitter with lift table and 4 way wedge #14
Just don't understand why you built something nice, and put galvanized water pipe fittings in the hyd circuit.
Recommend you replace them with hyd fittings.
JJ, I just haven't gotten to that yet, but i will getter done. It's hotter up here then it is in Jacksonville now. Have a nice day.
   / Log splitter with lift table and 4 way wedge #16
J_J is never freakin wrong! I swear the man is a plethora of info
and he calls a spade a spade...LISTEN TO HIM, NOW!!!
What is the rating for a 1/4 or 3/8" Mallable Street 90 J_J ? 150 Pounds?
Be VERY careful till you FIX It bro.... I am a plumbing contractor,
I have seen HOLES no less in mallable fittings! BELIEVE IT. You could build
pressure then POP, and you could get a 2500 PSI hydraulic fluid
squirt to the inner thigh and the twins are now quads...BELIEVE IT .
GAWD DO NOT DO IT PEOPLES!
Nice Splitter BTW...
   / Log splitter with lift table and 4 way wedge #17
One pin hole and hydro. fluid is enjected under the skin and you have a trip to the hospital and a while to stay there as well. hydro. oil is very poisionous and you DON'T want that to happen. Dont even crank the engine with those fittings in there!!!
   / Log splitter with lift table and 4 way wedge #18
Sweet build !!!!!!! I would strongly agree with changing those pipe to the proper fittings, there cheap. Wouldnt want you to lose an eye now!!!
   / Log splitter with lift table and 4 way wedge #19
Your splitter looks great...but those pipe fittings are a death trap!
thanks
DSC00093.jpg Just got new hydraulic fittings installed. Video will be coming soon.
FUEL CELL (A58214)
FUEL CELL (A58214)
Sterling AT (A56436)
2017 Ram 1500 Pickup Truck, V6, 4X4, Automatic Transmission, 212,570 Miles (A56438)
2017 Ram 1500...
Forklift (A59228)
Forklift (A59228)
2020 Kinze 3505 High Speed 6/11 Planter (A56436)
2020 Kinze 3505...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
