Log Splitter
/ Log Splitter #41
I built a splitter with metal that I had available. With that and the hydraulic cylinder, spool and hoses that I bought and running it with the tractor hydraulics it cost about $300. I used a 4" cylinder, figuring 2000psi from the tractor my little black book tells me that it is about 13 ton of force. So far that has been ample. Most of what I have to split is only 8-10" diameter, the biggest was about 18". It has walked through everything with barely a notice from the tractor. I run the tractor about 1400 RPM, it runs nice there, uses very little fuel and supplies enough oil that I seldom wait on the cylinder to retract.
I looked at one someone else had built and immediately saw two things I didn't care for, the cylinder moved so fast that I felt the need to count my fingers afterwards and it didn't have enough power so he might have to reposition and hit the same block a few times. Too small a cylinder=too fast +not enough power.
Mine moves slowly enough that I don't feel like my hands are at risk and it doesn't ever refuse to split. So far.
I mounted it on a 3pt carry all that I made and can have the splitter sticking out the back or cross ways and operate it in both positions. I split the wood at the tree, stack it into the carry all and when that is full I drive the tractor back to the shop and stack the wood onto the pile. For the little bit of wear and tear on the tractor I prefer to use it rather than having another engine to maintain and store. If I live long enough to wear out this tractor I will go buy another one.:D
/ Log Splitter #42
I have a TSC Speeco, I like it on a L3130. Slow but as fast as I am!
Also vote for wedge on ram, so you don't have to pick up wood to split smaller.
2006 Heil DOT 406 Comp Fuel Tanker (A64194)
2006 Heil DOT 406...
2017 Ford Transit 250 Cargo Van (A64556)
2017 Ford Transit...
ELECTRIC POWER WASHER (A64278)
ELECTRIC POWER...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A64553)
Pallet of...
Swict 84in Tooth Bucket Skid Steer Attachment (A64553)
Swict 84in Tooth...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
